SOURCE: dell 924
What do you call the encoding strip? Do you means the contact strip on the back of the cartridge? If so buy a new cartridge. If you mean part of the printer-did you put it back correctly- if still in trouble-take a look at www.fixyourownprinter.com. If no luck there try the Dell Tech support team If still out of luck Buy a new printer-
SOURCE: The cartridge carriage has stalled
If you can remove the dust from the paper lifting area with the help of petrol or ip (all the gararis) and reinstall that portion, change the encoder (which goes from the carriage) and clear the round encolder with the help of wet cotton. Greecing the cartridge park area and then check it. If you find any problem then contact me at [email protected]
SOURCE: Lexmark X1150
"Carrier stall" Error and the Carrier Slams in the Printer
If the printer carrier is slamming into the side of the printer, please try the following:
SOURCE: Printer Carriage Violently Slams Back and Forth
The encoder strip is out of it's way, or is removed...
SOURCE: Okidata 320 Turbo print head carriage slamming
There is a Optical sensor under the print head drive assy. You might have dust blocking this sensor.
