Question about Troy-Bilt 32cc 4Cycle Backpack Blower
Lost my manual,what engine oil to use for my troy bilt tb4bp gas blower ?
  • 3,740 Answers
You can find your manual here:
http://manuals.mtdproducts.com/mtd/Safety.do?BrandCode=10001&pid=235248&model_num=TB4BP&serial_num=100063&filename=769-03148c.pdf
You must choose accept to open or download the manual.
769-03148c.pdf is the file name.
Or go to this page and click View manual after entering your model and serial number:
If you do not know your serial number enter 100679 and you will still see your manual.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
7.9 Mb download! The informatiion you seek is in the manual on page 8.
SAE 30 SF or SH or SG (3.04 fl oz total capacity to be changed every 25 hours)
Thanks for choosing FixYa,
Kelly
Posted on Aug 29, 2011
    New Friend:
What kind of oil for law owner model11a020b02996932. Btiggstratton300 series.
Posted on Jun 05, 2013
6ya staff
SOURCE:
Diagram of tb4bp troy bilt backpack blower fuel line assembly
Troy-Bilt would be the most likely source.
Jul 17, 2017 | Troy Garden
Pull string broke how do I replace it
Don, Instead of me writing a book to ya on how to do this. A much much easier way to do this is to go on you tube.com
In the search menu, type in how to replace starter pull rope on (make) leaf blower...etc..
This way you will have visualization to go along with the instructions.
It's not super difficult, you can do this!! Good luck
Oct 18, 2015 | Troy-Bilt tb4bp ec backpack gas leaf...
Can i get piston rings
sorry not from us perhaps a troy built dealer can order some for you
Aug 01, 2015 | Troy-Bilt 32cc 4-Cycle Gas Backpack Blower...
How do I drain the oil from my Troy bilt 2100 squall snow blower so I can change the oil?
You need to remove the lower panel to access the engine. In the engine blow-out, the oil drain plug is numbered 77 (bottom of the crank case).
25256884-5livr0uqynklw3svefpqfefw-2-0.png 25256884-5livr0uqynklw3svefpqfefw-2-2.png
Oct 26, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
TB4BP won't pull
crankcase could be full of fuel causing it to hydro lock take plug out and see if it will pull over be carefull though if it's hydro locked with fuel it will pump out of the sparkplug hole. the rope may be off of the starting pully as well
Aug 26, 2012 | Troy-Bilt 32cc 4-Cycle Gas Backpack Blower...
What type and grade of oil is required. I have lost my manual and do not remember what oil is required. Troy model TB4SC gas blower.
Any 2 cycle oil will work. Then mix 1 gallon of gas to 1 container of 2 cycle engine, shake well and pour into your blower.
Aug 10, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Troy-bilt gas blower/vac stopped and pull cord won't come out
NOPE You can buy new cheaper than have this one repaired, Also I don't recommend using these for a vac on leaves. Leaves are very very dirty and these blower vacs usually dont last long when used as a vac. The seize problem was from an improper fuel mix. THE next one you getone use a little more oil, than says in the owners manual. Like if it says 50/1<<>> mix 40/1 more oil will just foul the plug and oil the muffler,but you will not have a seizure problem. I have never had a problem with a 40/1 mix .
Oct 21, 2009 | Troy Bilt 31cc Quickshift Blowervac, Model...
Troy-Bilt 32cc 4Cycle Backpack Blower Logo
1,061 people viewed this question
Top Troy-Bilt Garden Experts
Wayne McNeil
Colin Stickland
Colin Stickland
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
