SOURCE: I put a new memory card in our Kodak EasyShare
Your camera is only supporting SD/MMC Cards (up to 1 GB)
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.
1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
SOURCE: I have pics stuck in
To use your card from now on, make sure to set the picture storage location to Auto.
Testimonial: "Perfect! Worked great thank you gor taking the time to solve my problem!"
SOURCE: I can't seem to format
The problem is that your camera is only compatible with SD cards, not
SDHC cards. You bought a larger card for your older camera, not
noticing that it was SDHC (or not knowing that it mattered). The new
card doesn't work, not because it or the camera is broken, but because
it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC
cards but some have errors; they disable half of the chip and sell it
as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because
they're cheaper, but 4Gb SD cards do exist. They are so rare that I've
even seen a guru on this site claim they don't. I did own one once, but
it was very expensive and turned out to be so unreliable that I had to
return it. I don't recommend
looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it
doesn't say "SDHC" on it.
SOURCE: I cannot format
The C875 works with MMC and SD cards. Your new 4GB card is actually an SDHC card. While it fits into the slot it is electronically incompatible and will not work. You need to use SD cards, which max out at 2GB.
