You need to try Silica Gel Packets to dry out your phone. There was a good article on associatedcontent.com that explains how to dry a wet cell phone, iPods, or any electronics.
You need to place your cell phone in a zip lock bag with Silica Gel Packets. Silica Gel will remove all the moisture from the phone and its components, something air drying will not do!
Just Google "Silica Gel Packets" and you will find several companies selling these products. There is also a web site called: http://www.SilicaGelPackets.com that has them.
If this is a JVM Error you will need to reload the operating system to the device which OS 5.0 was released earlier this month, you can obtain the software from the carriers website
Your Blackberry probably just needs a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry
to factory settings. Download the Blackberry Desktop manager and run the
application loader. If it asks you for a password, you can enter it 10x wrong and that will wipe the blackberry as well.
Your blackberry probably just needs a firmware restore. Here's a guide on how to restore the blackberry firmware. Download the Blackberry Desktop manager and run the
application loader.
You need to reflash the OS on the phone you should take the
battery out first then connect it via the usb cable to the laptop/pc
you are using then open the blackberry desktop manager,click on the
apploader, then install the OS.
pls not that when u click on the apploader the pin should be
PIN:UNKNOWN you make need to do this like 4x before the pc sees the
pin:unknown but it will work once it see the pin:unknown you can
re-insert the battery and continue with reflashing the phone
