Not familiar with your model, but the problem sounds generic. I am guessing your set is hooked to a cable tv box, and that is where you need to change channels. I also guess that when you changed channels on your TV you probably moved from channel 3 to either channel 2 or 4 and the cable tv box is not sending to those channels so you lose picture and sound. Now, more guessing, you try to put the channel back to 3 on your TV, but still nothing happens. OK, if close so far, there are a couple of things to try. First, be really sure you are actually going back to the same channel you started with. Assuming you don't actually have the signal coming in on an auxiliary line-in and that you had it coming in on a channel, you may need to reset the presets on the television so that it recognizes the one important channel the cable tv box is sending out -- just follow your television menu to select or set channels. There is one more possible easy problem ... I have seen this one happen, after getting the channel correct and reset, if it still doesn't work, you mght need to turn the set off and wait one minute, then turn it back on WHILE the cable box is ON. This can cause the set to RE-Latch onto the cable box signal. It really doesn't sound like something is truly broken or needs replacement, sounds more like a user error. If your set is still under warranty, just call the Panasonic hotline (find it in Google, and they may be able to walk you through exact instructions for your model). Hope this helps.
2. Press the RECEIVER POWER button on the remote.
3. Press the UP ARROW on
the remote, about one press every two seconds. Stop as soon as the sound bar turns
off. This process may take several minutes.
4. Press POUND (#) on the remote. The VCR MODE button will
flash three times.
(VCR button instead of TV button)
5. Press VCR MODE button, then red TV button on the remote to turn on the sound bar. Press
VOLUME on the remote to confirm the remote controls the sound bar. If this does not
work, return to Step 1.
Remember to press the SAT MODE button to return to the Satellite mode to change channels.
