ISOLATE THE MAINS POWER BEFORE OPENING ANY PANEL ON YOUR APPLIANCE
There are sometimes up to three heating elements in simular types of ovens.
A Visual inspection is required to accertain which is the element not working, remove rear panel, there is odd types that have the element to the side of the fan assisted oven, have a good look when panels removed. The blow element usually has a blow out hole with Black Gray at the point it will feel rough not smooth like the rest of the element case, the second way is a bulge on the surface skin, it should be easy to identify. Part could be obtained through
www.whitegoods.co.uk you will need the model and serial numbers. Some models you have to remove the fan or fans if twin, some models have top fan usually no element in the top except grill.
Hope this has been helpful please send me info if more tech is required.
John
