Hi there
maytag speed queen dryer LGS10AW-@ 13 yrs old- trips the breaker everytime the button is pressed to start it---just started doing this----breaker is fine
simple and economical to fix or should we look at a new dryer?
The message "Push Search 99" displayed on your Speed Queen dryer typically indicates that the dryer is in the diagnostic mode. This mode is used by technicians to troubleshoot and diagnose any potential issues with the dryer's operation.
To exit the diagnostic mode and resume normal operation, you can try the following steps:
Press and hold the "Start" button or the "Cancel" button on your dryer's control panel for approximately 3 to 5 seconds. This should exit the diagnostic mode and return the dryer to normal operation.
If the above step doesn't work, try powering off the dryer by unplugging it from the power source or turning off the circuit breaker that supplies power to the dryer. Leave it powered off for a few minutes, and then plug it back in or turn the circuit breaker back on. This can sometimes reset the control panel and clear any error messages.
If your Speed Queen washing machine is stuck on a cycle, there could be a few different issues causing the problem. Here are a few things you can try to troubleshoot the issue:
Check the power supply and make sure that the washing machine is properly plugged in and receiving power.
Check the fuse or circuit breaker to make sure that the washing machine is not tripping any electrical circuits.
Make sure that the washing machine is not paused or paused on a cycle that is longer than usual. If the machine is paused, simply press the start button to resume the cycle.
Make sure that the washing machine door is properly closed and latched. If the door is not properly closed, the machine may not start or may get stuck on a cycle.
The PF is a power failure code and it indicates the control is not sensing any line voltage
Check the circuit breaker for the dryer is not tripped. The PF could be caused by a voltage drop during a storm but you should be able to clear it and run the dryer
If you hear the motor then the belt is broken If you have the control panel working it is no guarantee that the breaker didn't trip Find the breaker in your breaker panel and reset it.
Is there power at the dryer receptacle? Is the dryer wired directly or does wire from electrical breaker go to a receptacle first? Have it checked with a meter. If unit is wired directly have it changed to a receptacle and cord. Make sure there is power at the connections on the dryer. If everything is okay, then it is a dryer problem
