I turned TV on. It flashed and went out. I have sound but no picture. The TV is only 2yrs old. I hope it's only a small fix. PLEASE HELP!
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Generically speaking anything in the horiz deflection, hv development area will cause a no pix symptom, also a problem in the signal processor section, video river and output section as the crt/socket assembly. I would also check the lopt transistor and probably the fuseable resistors around the lopt.
TV went off for a couple of seconds, then powered back up with no picture. Does not even show graphics. what to do?
