Check fuel level and make sure the fuel valve is on. Beyond that inspect the spark plug for fouling. Use the choke appropriately. If it has been run with the choke on, it may have carboned up the plug. Make sure the magneto grounding switch is in the run position.
The first thing I would check is the oil level...when the oil was hot it still was high enough to keep it running, but then it cooled down the oil level drops slightly and then the oil sensor will not allow it to start,
Check oil and add as needed and then retry to start.
heatman101
didnt work, the oil level was fine. anything else you can think of?
Did that already, still the same symptoms.
