Question about Toshiba Satellite A505 Notebook
My Toshiba Recovery Wizard freeze at the "Initializing the partition. Please wait..." I did not make a recovery disk. Please help with fixing the problem or let me know where I can get the Recovery disk online.
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 26 Answers
SOURCE: boot Recovery Wizard
try f1 f2 if that dont work then f10 f11 or f12 it has to be 1 of them
Posted on Oct 07, 2009
specialistel
  • 8909 Answers
SOURCE: i have a toshiba recovery
I would say that was too long and there is a problem somewhere. I would run CHKDSK/F straight away to clear any disk errors and try again.
Hope that helps.
Posted on Feb 24, 2011
Toshiba no bootable device--insert boot disk and press any key
try booting from a Windows installation disc. Choose the repair installation option. If this does not work, you may have to erase (format) your whole drive and start over again by reinstalling Windows from scratch.
Before erasing the drive, you might want to pull it out, put as a second drive in another working computer or inside a USB hard drive case and download all of your information from it. Otherwise you may have a mess on your hands with lost data/documents/photos.
Jan 21, 2013 | Toshiba Satellite C655D-S5084 Laptop
Problems during Recovery of Factory Default Software
Don't stop the presses during recovery
its too bad to stop
wati more than 3 or 5 hours
cuz it depends on your pc specs
Dec 13, 2012 | Toshiba Computers & Internet
I have an older toshiba laptop and i want to reset it to factory defaults because it used to be my sisters and now its mine. help?
try this
Hard Disk Drive Recovery using the recovery partition
You have the options of recovering your system using the Hard
Drive Recovery partition
to the factory-set default, or recovering
just your C: drive and leaving other partitions (for example, a D:
drive) intact, or changing the size of your C: drive and then
recovering it.
To recover your hard disk drive using the utilities stored on your
computer's HDD:
1 Make sure the computer is turned off.
2 Press and hold the 0 (zero) key on your keyboard while
powering on the computer. When the computer powers on, the
Toshiba Recovery Wizard screen displays.
3 Select one of the options, and then click Next. The options are:
? Recovery of Factory Default Software
? Erase the hard disk
1 On the Toshiba Recovery Wizard screen, select Recovery of
Factory Default Software, and then click Next.
The Recovery of Factory Default Software screen appears.
(Sample Image) Recovery of Factory Default Software screen
2 Select Recover to out-of-box-state, and then click Next.
A confirmation message displays reminding you that all data
will be lost during the recovery process. Be sure to save your
work to external media before proceeding.
3 Click Next to begin the recovery.
Once complete, a message displays that the HDD has been
recovered.
4 Press any key on the keyboard to restart the computer.
To recover only your C: drive:
1 On the Toshiba Recovery Wizard Screen, select Recovery of
2 Select Recover without changing the hard drive partitions.
A confirmation message appears, reminding you that all
information on the C: drive will be lost during the recovery
process. Be sure you have saved your work to external media
before proceeding.
3 Click Next to begin the restoration.
recovered.
4 Press any key on your keyboard to restart the computer.
Jun 12, 2011 | Toshiba A105-S4054 Notebook
I want to recover my computer to factory settings
As soon as you press the power button on your notebook, Keep tapping F8 repeatedly. Another screen should pop up with a list of commands (safe mode / start up repair etc) Near the bottom of the list you should see an option to ReInstall windows / Reset to factory Default. Select which one you prefer and follow the simple instructions.
Hope this helps and please rate thanks.
Mar 13, 2011 | Toshiba Satellite L305D-S5881 Notebook
I have a toshiba recovery wizard running but it said to preparing, initializing the partition. please wait but it have been two hours saying that, how long does it take before i can do a recovery on my...
Hope that helps.
Feb 24, 2011 | Toshiba Satellite A505 Notebook
I have a satalite 300 had a bad virus,decided to preform toshiba recovery wizard.(clicked next.)Warnig sign comes up(when the recovery is executed,all data will be deleted and rewritten,(CLICKED YES)new...
try using ActiveBoot suite v5.0.5, when turnig on your computer. This program will scan your computer and show u all the errors,missing files, wrong dll,...and repair them. It worked very well for me as I had a TROJAN virus on my Toshiba satellite 300 and couldn't even boot anymore.
After that try use the RegistryBooster tool witch solves every windows problems.
I hope this will help. Good luck :)
Feb 19, 2011 | Toshiba Satellite Pro L300 Notebook
How doI reset my Toshiba Laptop with Vista 64 bit to factory settings?
There are two ways to reset your Toshiba Laptop to factory settings.
First is using Recovery Media Disc and the second is the hidden partition on your hard drive.
If you're going to use Recovery Media Disc follow these steps:
If you have two or more recovery media disc try to insert first the disc that has a label of 1 of 2 or 1 of 3. Then turn of your laptop.
Make sure that the disc is inside. After that try to find the letter "C" key on your keyboard. Now turn on your laptop and keep tapping the letter "C" key. If you have successfully accessed the Boot Menu choose Toshiba Recovery Wizard.
After choosing the Toshiba Recovery Wizard there will be a big warning screen that will appear choose the option yes and after that you will have a series of option. Remember to choose always the first option after the big warning screen appears.
That's it. You will have a message that the Windows is initializing files.
That process will take 1-2 hours for it to finish.
Hidden Partition on the Hard Drive.
Turn on the laptop and as soon as the laptop turns on press and hold down the number 0 key (the number 0 it should be on the top of the keyboard beside the number 9 key) keep 0 pressed until Toshiba leading innovation appears. Usually you will have a beeping sound when you are trying to access the System Recovery of the Hard Drive. That's an indication that you have successfully accessed the Systrem Recovery of the laptop.
Wait for the screen that say Windows is loading files.
After that you will see a big warning screen the choose yes and
Choose 1st option always.
Cx able to initialize the partition.
Disconnect cables and turn off the wireless switch.
Recovery would take 1-2 hours for it to finish.
Nov 13, 2009 | Toshiba Satellite L305D-S5904 Laptop
System recovery
Hi
Please go into my conputer and check whether u have a recovery partition or not..... If you have... restart your system and tap on F11..... go to recovery partition... U'l get a pop up to create recovery cd's.... Plz create the cd's once u get the pop up
Oct 22, 2007 | Computers & Internet
Toshiba Satellite A505 Notebook Logo
1,339 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
