If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
source Samsung Service Center toshiba repair wash machine repair
Consult your users manual for specific instructions on oven programming issues. A manual can be located online at www.repairclinic .com if you need one.
Press the helpful button and check link below for various models
First power off your TV using the remote, then press following buttons quickly on your TV remote: Display (or i+) + 5 + Volume Up + Power
It'll show the hidden service menu on your TV screen.
Once you enter into service menu, you can press Menu (or Options) button again on your remote to switch between various service modes such as Digital, Chassis and VPC.
To navigate between available options press 1 or 4 buttons. To change or modify their values press 3 or 6 buttons.
To save your changes, just press Mute + 0 (or Enter) buttons on the remote.
To restore settings to factory defaults, press 8 + 0 (or Enter) buttons. PS: For some new models the above mentioned method might not work. You can try following key sequence to access service menu in those new models:
While TV is on, press Left + Right + Mute + Center button + Mute + Menu buttons.
Service mode menu enter procedure differs model to model. If you wish to get more, check the site linked here. It has service mode options to many models. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type
in the model name to your set in its search box, or view it in Mosaic
/Timeslide option.
You're discussing about the entry of its service menu I assumes and posts this solution Just press 1,9,3,4 digits by remote control, must lead you to its service mode option. If you want more options to enter the service mode to different Samsung TV models, check this site.
Download its repair manual and try to find out the reason. You have to enter ins service mode options to make it right. You must have through knoledge about the adjustments to do there, otherwise, an irrepairable set will be the result. To download the repair manual click here.
