True problem is dasboard light won't got out and drains battery after 8 hrs. Seems a possible light modual issue by notes i read onlineTrue problem is dasboard light won't got out and drains battery after 8 hrs. Seems a possible light modual issue by notes i read online
You can't post conmments that contain an email address.
there will be a second fuse behind the radio its self , remove the radio and check that one , also be able to check wire connectors if the fuse blows again when renewed
The fuse box should be on the right hand side located at the heal of your shoe if you were
sitting in the rear seat behind the passenger seat. its a 25 Amp fuse
#14
Please if you can get into the car, beneath the driver side underneath the steering compartment you will get the fuse box there. Check the map and replace the fuse that has cut off.
I to have a 1988 Daimler 3.6 vanden plas. I would greatley appreciate if some one could let me know about any information on this model, ie; what made the vdp different from the standard daimler 3.6, production numbers and origional cost. In regards to your question, my daimler also said it had fuel failure. I put some injector cleaner in with the petrol and the warning hasnt come up since. As for the circuit 2 failure, it could be numerous things, but start with checking the fuses in the left side fuse box. It could also mean that a light bulb or other elecrical item has a broken circuit somewhere.
