My player suddenly stopped working, the LED on it blinks green-yellow, like there were no music files on it, when I push the play button. The computer(PC) recognizes it, but iTunes doesn't. I can't even use it as a removable device, Explorer can't open the drive. Apple Updater fails to update or restore the device. I heard that lot of people have this problem. Does anyone know a solution? My warranty is over...
Hi
Ur Ipod shuffles needs to be reset to factory setting, you will find the utility for Mac and windows machine at:
http://support.apple.com/kb/HT1293?viewlocale=en_US
http://www.techspot.com/downloads/3726-ipod-shuffle-reset-utility.html
1. Reset the ipod using the utility
2. Run itunes application to create profile : after you have reset the Ipod just start itunes and it will ask you to provide a profile name, just provide any name and select okay.
I had the same issue, got it sorted using the windows utility.
Should work for u as well.
Thanks
Krishnendu
Place the Shuffle in your PCs USB.
A dialog box may pop up. Do not click it.
Do not click any dialog which pops up asking if you want to put songs from this pc onto this ipod, deleting the old ones.
Click edit, preferences, then select the "ipod" tab.
Check the box "enable disk use".
Move the slider to the right so that it is set to more data (maximum), and 0 songs.
Click ok.
Right click your start button and select "Explore".
Navitage to My Computer, and then seek the drive which represents the shuffle.
Right click the drive and select format.
Leave the options as they are.
Click Start.
After formatting, click eject ipod (icon in the bottom right of the itunes window).
Remove the shuffle.
Re-insert the shuffle.
First try resetting the ipod shuffle - Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure place the switch in the off position. It it still doesn't work, Make sure all your software is up to date. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Now try to restore your ipod again.
To fix while it is connected to my computer
SOURCE: Shuffle not working, blinking green-yellow led.
Try to do a restore:
Connect to your computer and open itunes.
When you first open itunes you should be in "Devices"
Make sure you're in the "Summary" tab and you will have a button that says "Restore"
Click that and it will do the rest.
You can log on to the apple shuffle instruction manual and its all online.
hope that helps!
this is totally a error 1418. Search my answer regarding this problem, it is totally fixable. don't get rid of it. I just fixed one 2day and I'm now preaching the good news.
If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
turn it on push play and all that happens is the green and yellow lights are blinking
IT IS BLINKING GREEN AND YELLOW
I have tried to reset as suggested. It's still blinking yellow and green. When I turn it on I hit the volume botton and still nothing. It is fully charged. I'm out of ideas...please help.
Thanks in advance
I just got an ipod shuffle from the national gaurd. I used it once, i can take the ipod off the charging station turn it on, and press play, nothing happens. except the light by the off button, turns yellow and green. my ipod is telling me that there is no songs on it. but my computer says there is. What is going on, this thing is bran new
my ipod is doesnot take charge. it blinks green then turn off.
same problem
Same problem with me in ipod shuffle
i perss play and a red orange light blinks at me and it wont play and my copmuter doesnt reconise it
I tried charging it nonstop for a whole day
I would be the 12th other user with the same problem. Â What to do?
when i turn on the ipod shuffle and press play the ipods orange and yellow lights flash one after the other and the music doesn't play.
blinkin green and orange light will not play songs
hi my ipod shuffle 512mb have some problem. when i plug it into computer it show me zero mb space. it cant open in computer. it property show zero mb space what can i do
my ipod is blinking yellow and green idk wats wrong wit it
Its The Exact Same For Me
My Ipod Shuffle, It blinks green and yellow
And wont read any music
Idk Whats Wrong With It
Can Anyone Help ?
its ******** when i press play the light blinks green and orange and it wnt play the music
