Coleman Powermate Premium Plus 6250W Portable Generator Logo
Posted on Aug 27, 2011
Generator is leaking fuel - Coleman Powermate Premium Plus 6250W Portable Generator
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 27, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
435
Points
On most Coleman generators, there is a rubber seal that literally evaporates if left in time. Most people don't even see it because it has gone. You must check if any seals are missing. Make sure that the gas regulator is screwed as tight as it can go because if it isn't, it will leak like a sib. Last problem could be the open and shut valve is stuck which is another thing that happens when it sits over time without using it. You need to start it up and hold the choke and that will stop the leak and let it run for a couple of minutes and let go of the choke. It should open and close the valve with no problems after that.
Etq tg3000 portable generator is leaking gas from carburetor into air filter. Any suggestions
PDF]Manual - Northern Tool + Equipment
www.northerntool.com/images/.../166020.pd...
Northern Tool + EquipmentThe ETQ air-cooled gasoline generators are widely used when electrical power is scarce. Our generators provide a portable mobile solution in supplying power for field ... 5.5 Hours. Fuel Type. Premix 50 cups of Gasoline to one cup of 2 stroke oil ......Leaking carburetor, clogged fuel pipes, sticking valves, or other damage, ...
[PDF]Owner's Manual Model TG4000
I have an Onan 6.5NH-3CR generator in my motorhome. It will not start, but the fuel pump continues to cycle until the fuse is removed. Any suggestions?
You likely have a break/leak in the line between the fuel pump and the gas tank. It may likely be right adjacent to your fuel pump. This scenario causes an air leak and doesn't allow the fuel pump to retain it's prime so it cannot build up pressure to actuate the auto shutoff.
My troy built 7000 generator is leaking gas. I replaced a gasket but it is still leaking. HELP!!!
With generators sitting long term not use carburetors tend to get gummed and need a good cleaning and depending how bad this gumming and corrosion is either a carburetor repair kit or carburetor will be needed.
It best to use a good fuel stabilizer in the fuel for short term storage and for long term to shut the fuel flow off and run the generator until it uses up the fuel in the carburetor.
Engine codes PO 128, PO 440, PO 456 and PO 622
Trouble Code: P0128
Thermostat Rationality Test
Possible Causes:
Check the operation of the thermostat (it may be stuck open).ECT Sensor is contaminated, damaged or it has failed.Inspect for low coolant level or for an incorrect coolant mixture.Trouble Code: P0440
EVAP Purge System Fault
Possible Causes:
EVAP purge valve vacuum supply is leaking or clogged.EVAP purge valve is stuck closed.EVAP purge solenoid has failed.NVLD assembly (leak detection) is damaged or has failed.NVLD switch circuit is open or the NVLD switch has failed.Ground circuit is open.PCM has failed.Trouble Code: P0456
EVAP Small Leak (0.020") Detected
Possible Causes:
.EVAP fuel tank or canister vapor hoses leaking or damaged.EVAP system component leaking, fuel cap loose or missing.Leak detection pump damaged or leaking.Trouble Code: P0622
Generator Field Control Circuit Malfunction
Possible Causes:
Generator field control circuit is open or is shorted to ground.Generator field control circuit is shorted to system power (B+).Generator field ground circuit is open.Generator is damaged or PCM has failed.PCM has failed.Here are the codes and causes.
1helpful
2answers
Fuel leak on powercraft 720 generator
The fuel hoses can leak if bent in an unreasonable fashion during installation or upon completion of installation.
McColloch 7800 generator leaking fuel from the carborator.
rebuild carb using new needle and float if float is full of gas and sinking
1helpful
2answers
Generator is leaking gasoline out through the carburator when not running. Also, fuel shutoff valve at bottom of gas tank will not shut off completely. What are probable causes and price to fix ??
Most often fuel leaking out the carb is caused by a needle and seat problem in the carburetor / the float level shaft screw may have come loose due to the vibration of the engine ,this will cause a leak issue with the needle and seat as well. To complete the repair the carb will have to be removed and cleaned. Replace the needle and seat if necessary an then replace the carb.
1helpful
Fuel leak
Have you tried to tighten the generator onto the valve assembly using pliers? This worked for me.
Top Coleman Electrical Supplies Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
