This problem login problem username and password are being requested by http://192.168.2.1. The site says: "RT-N10+
You should call on- (( +1-800-585-2494 )) Toll Free Asus and get help for Asus.
Well, you may contact to asus tech support at toll free number- 1-800-585-2494 and fix the problem instantly.
For setting up the Asus router, an easy web-domain has been provided by the company is router.asus.com . This web address lets you set up every Asus router. All the connected devices to the network can access this connected device. For easy Asus router setup, you need to access the Asus router login page.
SOURCE: Linksys wireless card with ASUS WL520g Router - encryption error
Sorry I re-read my request for help and realised it sounded confused! It was 2am in the morning when I posted it - totally frustrated with the ASUS router interface software. :) I will attempt to explain again calmly this time - apologies for the hysterical cry for "help"! :) -you know how computers and process of elimination processes can get!? New day no wireless connections on my computer 1. I setup a new wireless connection via windows xp wizard.... I choose Auto (not manual this time) system "generates a "network key" automatically for me i.e. (WEP/WPA KEY) - it gives me a 26 hex code which I print for future reference input (it autom. uses Data encryption type WEP, Connection type: ESS ) Network connection name Jen's Wifi 2. I press the reset button on the back of Asus WL520g router; hold for 30 seconds. 3. go to "view wireless connections" - I see "Default Automatic" - IT IS UNSECURED - but Jen's Wifi connects to "default" good signal etc. etc. Now this is where the problem starts - I want to password my wireless connection - I go to internet browser and (file server not found ) so I go to the address field and enter 192.168.1.1 - and get on to the ASUS interface software - login as "admin" go to quick set up and choose 2nd option connection type " ADSL requiring username password, PPope connection........." this type assigns ip address/es automatical (dynamic not STATic) also DNS keys. the PASS PHARASE I ENTER IS THE NETWORK KEY 26 hex code generated from the XP Wizard Wireless connection (WEP key 1 10 or 26 hex.... key 2, 3, and 4, shows below on the screen input as I type in my 26 hex code).... I name SSID as "Jen's Router" Save and restart Jen's Wifi connects to Jen's Router - It asks for network key and I enter the 26 hex again twice to verify - all good get CONNECTED BUT CANNOT GET INTERNET BROWSER CONNECTION - even with shut down power up re do etc.... SUMMARY; THE ONLY TIME I CAN GET BROWSER CONNECT IS when I use Jen's Wifi to connect to "Default" Wireless connection after reboot - i.e. I CAN LOG ONTO THE INTERNET ALL GOOD UNTIL PASSWORD / MY WIRELESS CONNECTION VIA the ASUS wireless router software. I tried finding new firmware latest drivers 2004 ...?? Any further input? Thanks for any assistance Kind Regards Jenny B 1. I go to 192.168.1.1
SOURCE: Can´t access 192.168.1.1 (router admin page)
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure that your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
SOURCE: asus wl-500w and modem
your sub net mask is wrong you have to put 255.255.255.0 and make 192.168.1.1 to modem and 192.168.2.1 to router
SOURCE: I have same issue and using Asus WL-520GC
HI! I will be more than glad to assist u in this concern..the reason why page cant be displayed bcoz the router and the modem wont talk to each other.. u are connect to the router but not to the internet..this are the possible solution.. .. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
SOURCE: We have just bought an
Hi
You have to get the IP address of your internet service provide and once you type this IP address to the address bar. It will go you to menu set up of the router and set it up there. The encode the new password set up.
You should call on (( +1-800-585-2494 )) Toll Free Asus and get help for Asus.
