Posted on Aug 27, 2011
How to install a cisco 4585 dvb box to the virgin socket in my home
1 Related Answer
Vitally Alcher
  • 1645 Answers
  • Posted on Dec 27, 2013
SOURCE: Connecting cisco 851 cable to virgin media superhub problems?
Did you follow instructions on the manual , re install the driver .
How do I reset a phoenix digital satellite receiver dvb 2800A without a remote it asks for a pin but I cant put one in without a remote
How to Reset the Phoenix DVBS2500A Digital Satellite ...
www.ehow.com > Tech
The Phoenix DVBS2500A is a digital satellite receiver built to capture free-to-air ... isno charge for accessing and viewing programs that the Phoenix can receive. ... press 7799 on the Phoenix remote control, and then press the "Enter" button.
How to Connect & Install a Digital Terrestrial Receiver ...
? 1:32
https://www.youtube.com/watch?v=bZzuN4a8GGE
Mar 2, 2012 - Uploaded by tvtradedave
http://www.tvtrade.ie/digital-tv.html. ... Up next. How to watchdigital channels without cable TV or satellite for FREE? ... TDT Colombia DVB-T2 Decodificador Multitech TDA Television TVDigital Terrestre Caracol HD RCN HD ...
PDF]Cisco D9865 Satellite Receiver Software Version 2.15 ...
www.cisco.com/.../Digital_Receivers/47-4035197-01_D.p...
Cisco SystemsModifications to this product not authorized by Cisco could void the FCC approval ...This Class B digital apparatus complies with Canadian ICES-003. ... Cisco D9865Satellite Receiver Installation and Configuration Guide ..... Performing a Factory Reset4-39 .... Provides an overview of the front panel and remote control.Missing: phoenix
1helpful
How do I connect a virgin v box to an old lg model?
The hdmi cable would not be compatible with your old style TV, if the Virgin box has a scart socket then that is your best option!
Connecting Cisco 851 cable to virgin media super hub Problem
are you using the cable modem as your router? if so then simply hard code your media hub to a static ip address in the same range that the router/modem communicates on. (private address side)
Virgin tvvo box
Not sure about about the transmitter but the magic eye thing is possible however you wouldn't be able to change channel unless your pointing your remote at your box because a sky box has power going through the magic eye but a virgin box doesn't
Device code for cisco RNG 150
Ok I know the post is kind of old, I mean the person asking about wanting to find the code for comcast Cisco RNG 150, all depends what Bose system do you have, the system I got is Cinemate GS series II that comes with an universal remote, and the codes for the Cisco brand cable box, it doesn't specify model code only Cisco cable box, anyways the codes are, 01877, 00877, 01982, now the last code worked for my universal control, don't know if it will work with other Bose controls, one thing I found out while browsing is that someone posted a cinemate manual with some codes but not for Cisco cable box they were for scientific Atlanta that are boxs comcast uses for the digital preferred system, the Cisco is use also for digital preferred but it has a different code, out of the three codes I posted earlier the first two were the same as the codes for the SA cable box, but the third one 01982 worked for mine. I hope this information will help someone. CEVICHE!!!!!
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
7helpful
Wat r the new ntl codes for the box usb september2010??
They have not changed.
If reflashing with the old firmware does not work, then virgin has introduced Nagravision 3 in your area. And thats it for now.
Virgin is bringing nagravision 3 all over UK area by area, as yet there is no workaround, and looks like there will not be any for the older boxes.
The newer boxes with ethernet sockets MAY get a fix eventually.
Google nagravision 3 and virgin for more info
7helpful
How do I connect my dvd player with a virgin box do I need 2 scarts in my tv?
Your virgin box should have two scart sockets,if you only have one scart socket on the tv then...Put a scart lead in the one marked tv on the box and plug it into the tv,then from av1 on your dvd take a scart and plug into the other socket on the box.If you cannot get the dvd to play when the box is on then switch the box off.
Eurovox codes
TELEWEST
5A 01
KEY 00 = 98 B0 BA 52 D3 21 08 B4
KEY 01 = D2 EA 29 B7 B5 52 E9 AD
Top Cisco Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Cisco Audio Player and Recorder Expert? Answer questions, earn points and help others
