How to turn wireless WiFi on/off Windows 7, 8, 8.1, & 10
Description
This article describes how to turn the WiFi radio on or off. Follow the provided instructions to enable the wireless card.
There are several ways to turn the wireless radio on or off.
Ensure that Wi-Fi is on. When you see a green check mark next to the Wi-Fi option, Wi-Fi is on.
Choose a wireless network from the list. Available Wi-Fi networks appear at the bottom of the screen. When no wireless networks are listed, you're sort of out of luck regarding wireless access from your current location. Optionally, type the network password. Touch the Password text box to see the onscreen keyboard. Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long. Touch the Connect button. You should be immediately connected to the network. If not, try the password again.
1. go to settings of your Tablet
2. click on Wifi
3.loo for the ON button
4 it will search nearby wireless networks around your place5
5. if you have a wireless router in your place then select by clicking it and press on Join button
6.it will ask you a network key....
enter networkkey (password access)
7. if have finnished, it will appear beside Wifi - the name of the network you picked.
enjoy wireless network...
PS: incase of trouble try resatrting your tablet and the wireless router network if you have.
Shutting down or rebbooting IPad, press and hold the small button switch on top of the ipad by 3-5 seconds
then theresa red arrow appearing and follow to where it want you to slide....
wait few minutes when it shutting down and it will be on sooner.... goodluck
In connecting through a wifi, there are two factors to consider. (1) Wireless Router broadcast and (2) Wireless Receiver.
Make sure that your network router is broadcasting wireless internet or wifi. Also, you have to know if you need a pass key or password in order to connect to the wireless network.
Now, given that there is a wifi spot, your laptop should automatically recognize the wifi broadcast and negotiate connection without your intervention. This will only happen IF AND ONLY IF your laptop has a wifi radio receiver and that it is TURNED ON. When it is turned ON, it will connect you immediately if the network has no pass key set. If there is, then you have to enter that key when you try to manually connect it. (Right click on wireless network icon on system tray. Then it should say: Wireless Network Available. Then Click CONNECT)
To turn your wifi radio receiver ON, slide a switch button to ON position depending on your laptop model. If you dont have that kind of switch, look for the wifi icon printed in the keyboard keys. In some laptop, it is in F2. Now Press FN+F2 to turn wifi radio receiever ON and OFF.
go to your wireless settings, where you can see the connections that your phone can find, hold your stylus on the connection and remove the settings. after that set up a new connection. problem should be solved
You have to have the "Other Half" so to speak... wat ya missing is someone else to connect to...
Usually one ALSO has a WiFi Router OR connect to an "Access Point" both of these provide a WiFi Signal that can be accessed by your Wifi.
blow are a couple of helpful links. To help you set up a home network.
www.techtree.com/India/Guides/
Setting_Up_a_Wi-Fi_Home/551-74315-560.html
www.microsoft.com/.../resources/technology/broadband_mobility/
hooking_up_with_wifi_6_things_to_know.mspx
