Caller ID on landline phones relies on signals from the telephone service provider. Some companies charge extra if you wish to enable the service, others include it automatically, so you need to check with them first.
Even if you have caller ID enabled, callers can choose to withhold their number. Large companies which make lots of outgoing calls (especially cold callers) often have their service set to automatically withhold their number. In many countries, all other callers can choose to do so by prefixing all dialled numbers with a short code, e.g. in the UK it's 141. Mobile phone callers can usually alter a setting on their handset so that caller ID is withheld when making outgoing calls.
Try to erase your phone's voice messages. Press ERASE 2 times while the phone is not in use. Caller ID is being activated by your phone provider. To use Caller ID features, you must subscribe to a Caller ID service. Contact your service provider/telephone company for details.
Caller ID is a staple in every iPhone. Your service provider may have blocked your Caller ID, so make sure to check with them first. To check if your iPhone has enabled the Caller ID setting:
just connect one end of the phone plug to the id caller,then connect the outlet of the caller id and fix it to phone...........even then if u hav problem, may be ur caller id doesn.t hav batteries..............otherwise u may hav some problem in the id caller socket where phone plugs r inserted................
only thing i can think is the IP function might be on. ( and of course, u do have the caller id through the phone company activated, right,,,,just checkin) . this funtion is not available in the USA. to turn it off, press SET/SAVE, press UP to select SET 4 AUTO IP, press SET/SAVE to select, press UP to turn on and off, then press SET/SAVE to confirm. hit DELETE to return to main screen. hope that helps.
tammy
