SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Hi there. Turn the camera on and go into the setup menu, look down the list for "reset" and reset it, then try another camera card. Please post back the results.
Hi there, My name is Rob and I can help you. Do this:
Make sure the camera is off and pull out the SD card. Look on the side of the card. You will see a little switch. One side says locked (or shows a little picture of a locked lock) the other side says unlocked (or shows a little picture of an unlocked lock). Make sure the switch is in the unlocked position and reinsert it properly into the camera.
This will fix your problem. Thanks for coming to FixYa. Let me know if I can be of anymore help. Don't forget to rate my answer a fixya!
Pull out your card and on the side of it is a white tab, slide it to the opposite direction. I don't have the same camera as you, but another Canon. good luck
