Mitsubishi WD-62526 Projection TV Logo
Anonymous Posted on Aug 26, 2011
WD-65734 Mitsubishi TV won't turn on. System reset
  • Anonymous Aug 27, 2011
    No lights of any kind. The problem occurred after a thunderstorm. It was connected to a surge protect device, which shut everything off. All other equipment worked after protect device was reset. Could be the power supply. Need help in further troubleshooting.
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Aug 26, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
Helped
4176
Points
22
Are there any lights lit on the front of the TV? Have you checked for a bad lamp? When you reset the TV the timer/power light should flash on and off rapidly for 60-70 sseconds. Does that happen?
    Yes, you're probably right. The power supply is evidently bad. I wouldn't recommend trying to troubleshoot a surge damaged power supply board. There are probably several components damaged on the board, not to mention possible safety issues. It would be much better to replace the entire board.
Screen went completely white but still have sound
Try with the Mitsubishi remote the soft restart, set on Menu,1,2,3, and enter.
1helpful
I need a code for my samsun blue ray to be used with the Mitsubishi wd-65734 remote
The Mitsubishi has a list of its codes in the owner manual and also I think has a search mode---can try all possible codes one at a time.
No owner manual? Google the model number of set with "manual" if cannot find let me know with a comment here and I will try for you.
SD TECH
1helpful
2answers
Mitsubishi wd-65734 65 in. Tv shuts off on its own and red lamp light comes on. after a few minutes i can turn it back on and works fine for a few min to an hr before doing it again. anyone no wat the...
Same thing on my tv after replacing lamp. Lamp manufacturer advised me that after changing bulb, tv must be reset or tv will go into safety mode and will not turn on. To do this on my model WD-65734 you must hold reset button in with a pen or paperclip for about 10 secs.The LED will start blinking for a few mins. When itstops you need to unplug tv set for about 1 hour. After this the tv will be reset.
2answers
Mitsubishi WD-60735 Control issues
This set has aside from the recessed front reset two more done with the Mitsubishi remote.
The soft reset "should" be with set on Menu, 1,2,3, enter
The hard reset requires a 4 digit number code and is based on model number and also done with the Mitsubishi remote--try to see if soft reset works at all on this model.
WD-65734 Mitsubishi TV won't turn on. System reset does nothing. Fuse OK.
Does the front light blink a pattern. If so this may be used to lookup the error codes.
The color on my Mitsubishi WD 65734 rear projection tv just went out. I did not hear anything. I just turned it on and had no color.
With the Mitsubishi remote: have set on and hit Menu, 1,2,3 enter to do a soft reset of the unit.
I would also suggest you check all connections if you are using a box for signal and look to see if have color from DVD or blue ray etc.
Let me know what you find with a comment here before you rate this solution.
SD TECH
I have a 65" Mistubishi WD - 65734 and have no
Yes,"LAMP" LED light indication front of tv bazel frame is on or blinking,yes mean tv projection lamp life are over.The whole tv warrenty only for a year,tv projection lamp should last at leat 1 1/2 or 2 years,by tv been on and watches used it like 4 or 5 hours daily?U never done tv replacement parts,any kinds before?Yes,hire a tv Tech. to do it.Shop around for a Tv tech.should replaced the projection lamp for u shoud be around $250 to $300 that including part the projection lamp.
2helpful
How to reset lamp timer on mitsubishi wd-65734
This model there is no reset for lamp timer.
Same problem on 18 month old Mitsubishi
As an experiment..plug the tv out of the wall. Wait. plug it back in. Does the green light stop blinking? If so, then the TV needs to go through setup/netcommand again. If not, the problem may not be an easy fix.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
