The main ones to tighten are the ones on the legs that you can see. What makes it really wobbly are the legs not being balanced or spaced apart wide enough. They should be extended out enough for them to be resting on the side of the top where they enter the motor housing, and the feet should be relatively flat on the floor. Push them out (don't force them of course) then use your foot to nudge them out until they're stable enough for your needs. I found it also helps to set this up on a carpet instead of bare wood floor. The swinging motion can sometimes rock the legs up/out a little and make it look unstable.
