I have a 46" Flat Screen TV. Model Number
    Scholar:
  • 115 Answers
First thing you do is to check the outlet if there is a power output the check the power cord and plug.If there 's a power in the power cord,Check the fuse of your television.The fuse is located at the power supply.You can see the power supply when you open the back cover of your television at the upper right side.Replace the fuse if busted with the same value of fuse.That's the step you can do first..Thanks..
Posted on Aug 25, 2011
6ya staff
SOURCE:
I have an element 40" hdtv model ELCHW402 it powers up, red light comes on but i cant turn tv on, light stays red
hi you may have a power supply fault, could be capacitors look for a tech in your area hope it helps
regards
shaun
Jan 25, 2014 | Element ELCHW402 40 in. LCD HDTV
ELCHW402 won't turn on
An internal relay may have failed.
Dec 08, 2017 | Element ELCHW402 40 in. LCD HDTV
My samsung tv is making clicking noises and won't turn on
Clicking noises may mean a power supply voltage is not staying correct or that board is bad---a suggestion: visit shopjimmy.com who has by model number a list of all the boards used in almost every Samsung Flat screen set made.
Jun 17, 2012 | Samsung Televison & Video
Element tv Model ELCHW402 won't turn on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_25_2012_3_07_58_pm.jpg5_25_2012_3_08_17_pm.jpg5_25_2012_3_09_15_pm.jpg
May 24, 2012 | Element ELCHW402 40 in. LCD HDTV
Screen won't turn on, no sound flashing light on t.v.
power supply problem check bad capacitor or out put voltages 5v and 24v
Aug 16, 2011 | Samsung UE-46B6000 46 in. TV
We have a 46 inch sharp tv model number 46SB54U won't turn on. The green timer light is flashing. We just replaced the power supply board thinking that was the problem. TV still won't turn on...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will helpout ......
Jun 25, 2011 | Sharp LC46SB54U 46 in. LCD TV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
