You will need to take the watch to a jeweler or a watch maker to get the correct crown.
Hi, When you get into the link choose a country and region to contact customer care for help...
http://www.longines.com/customer-services
Hope it helped..
You can find vintagelongines watch replacement 18k gold crown and all other replacement parts from http://watchpart.co.uk/longines-m-16.html. Visit thislink, scroll down and you will find the replacement parts. Hope this will help you. Good Luck.
Is this your watch?
LONGINES
Mans Wristwatch, 18 k Yellow Gold Snap - Back Case, Ref. 8541 -4,
original Crown with Longines - Logo, silvered original Dial, embossed
Gold Markers and Longines - Logo, Sweep Second, gold Index - Hands, 17
Jewel Movement, Cal. 284, Shock - Protection Incabloc , Fine -
Regulator, Leatherband, Switzerland, ca 1974, Diameter ca. 34 mm, total
Height ca. 9 mm
This is all of the information you should require in order to purchase a crown and I am sure your particular watch is vintage (probably 1965-1971) you can purchase the crown directly from a Longines Service Center or from Longines Corporate as they continued to use this classic style for a good quantity of watches, even in the present day. Go to Longines.com and under customer service you will see where to purchase "spare parts".
You wrote "I need the technical specifications of my vintage longines watch cal 284 18k gold hand wind 40 yrs old. These are the technical specs. for your watch. What is it you really are after? I cannot give you more than that and nor will any one else. You ask for information, I provide it and you do not specify what you are really after.
SO NOW, WHAT ADDITIONAL INFORMATION ARE YOU AFTER. LONGINES ONLY SUPPORTS SPARE PART LIFE FOR 15 YEARS AFTER A WATCH IS RETIRED. YOURS WAS JUST RETIRED. TO GET THE ORIGINAL PART, YOU NEED TO CONTACT LONGINES. SORRY IF THIS IS TOO CLEAR FOR YOU.
YOUR CROWN IS 34MM. THAT IS HOW THE DIAMETER IS MEASURED.
Best place to look is on Ebay these days. A lot of watch repairmen are selling parts such as for yours here
Here is a web link you can click onto to see
http://www.ebay.com/sch/i.html?_nkw=Longines+crystal&_in_kw=1&_ex_kw=&_sacat=See-All-Categories&_okw=Longines+crystal&_oexkw=&_adv=1&_udlo=&_udhi=&_ftrt=901&_ftrv=1&_sabdlo=&_sabdhi=&_samilow=&_samihi=&_sadis=200&_fpos=Zip+code&_fsct=&LH_SALE_CURRENCY=0&_sop=12&_dmd=1&_ipg=50
Hi limjoohai,
Longines guarantees the availability of its spare parts during a minimum of 15 years from the date of the production stop of the watch model concerned.If this period has elapsed and the spare parts are no longer available, they suggest that you send your watch via a Longines authorized service centre to the Longines head office in Switzerland for a repair estimation.
In the large majority of cases, they are able to find a solution for repairing your watch properly even many years after the minimal duration of 15 years has elapsed.
If you need spare parts for your Longines watch, contact the nearest authorized Longines service centre in your country. You will find its address in your guarantee booklet or on their website in the Customer Service section.
Hope this helps.
Thank you for using FixYa.
This answer does not solve my problem. It is a very poor solution. I need the technical specifications for my crown to purchase a replacement in the aftermarket. Look forward to your reply.
Your answer is no good. I had search ebay already, but no answer. I only want the technical specifications of my longines crown, cal 284 18k gold hand wind. Please comply.
This is not the answer. What you have given is the specifications of the watch outer dimensions. I need the specifications of the crown and not the watch physical dimensions.
Found nothing. Please give another solution.
I did not expect you expert to give silly solution. You stated the crown as 34mm. This is incorrect. The 34mm is the diamenter of the case and not the crown . the crown diameter is about 5mm. I want the crown opening diameter and the stem size.
No expert answers.Problem still unsolved. I want a refund!!
