SOURCE: DP-301U Printer Compatibility
Yes it will work. In my office i am using 1160 series printer .
SOURCE: Unable to setup printer driver fro D-Link DP-301U
I'm not able to install the printer driver Officejet 5610 when conenct to D-Link DP 301U. It always prompt for missing file such as hpzimc09.dll hpzstw09.exe, I'm using the CD proviede when I purchase the printer and also try on the installtion file downlaod from HP website.
SOURCE: HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
SOURCE: using HP Laserjet P1006. Is it compatible with DP-301U
Yes. I just got mine working last night. Key is to enable print services for windows through the control panel. Without that LPR printing does not work.
SOURCE: Printing Problem
i got my dp-301u to work fine with my hp1020 on 2 different
workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3.
once created go into the properties of the 2nd printer and change the
port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
