Hi
You need to reinstall the software on the CD that came with the printer or download and install it from here:
http://support.lexmark.com/index?productCode=LEXMARK_X4650&page=driversdownloads&linkSelected=node2%5Esubnode2&locale=EN&userlocale=EN_UK
Then save the downloaded setup files on an external hard drive ofr USB Flash drive for future reference.
I hope this helps
A
quick fix for most communication errors can be achieved by resetting the
printer and/or rebooting the PC. Simply disconnect the printer from your
computer. Reboot your pc. Unplug and re-plug the printer into the power source
to reset it. When the printer turns on, reconnect it to your computer. Then try
to print again once the computer fully recognizes the USB connection.
If
that doesn't help, try the steps below:
1.
Disconnect the printer from your computer.
2.
Rebrick (pull out power supply, black box where the
power cord is plugged in at the back of the printer, and put it back after 30
seconds).
2.
On your computer, go to Control Panel > Printers and Faxes.
3.
Delete the Lexmark print object.
4.
Reboot your pc.
5.
When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
