T'Con board fault. If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
SOURCE: Was watching tv( Toshiba Regza)and the screen went blank.
I have the same television and ocasionally the sound shuts-off, but I still have a picture.
What type of cable system do you have? What kind of converter box? I am trying to find out if it is the TV or converter box. I change the channel a couple of times and the sound usually comes back.
SOURCE: plasma tv will not turn on but red standby light keeps flashing
Cheaptech and dbtek
Thanks for the instructions, they worked great and your pictures were very helpful. I recommend that everybody try this before calling a service tech.
SOURCE: The TV will not turn on. Has flashing orange light
It sound like you have a bad capictor on the power supply. If you take the back off your tv, you will see little round componets. These are the capictors. The tops should be completely flat. You may need to put your finger on the top to feel if they are bubbled at all. Find the one that is bubbled and replace it.
SOURCE: 42" Regza #42RV530U won't turn on. Was working
not being funny but have tried changing the fuse or the mains lead if it plugs in the t.v
SOURCE: my toshiba regza 32cv505d will
The first thing to check is the horizontal transistor by the fly back and see if it is shorted, It will be mounted on a metal heat sink. Your TV has lost the high voltage and that is why it is in shutdown mode. To have it repair if taken top a shop, you are looking at about 150 on repairs,
