Lexmark X4650 InkJet Printer Logo
Posted on Aug 23, 2011
When attempting to set up my printer. After I go through the hardware set-up, it can't detect the printer. What should I do?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Aug 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
1694
Points
26
Did you install the drivers off the cd that came with the printer? And if so, check your drivers and make sure it shows that its there. Maybe then you could look online for a downloadable version.
3answers
Error 163 on oki c5500 printer
163 Toner Sensor Error, Color: Black An error has been detected in your printer's Toner Sensor.
1 Machine Check Exception A problem has been detected in the printer hardware
2 DSI Exception The printers main logic has attempted to look up an invalid address.
3 ISI Exception The printers main logic has attempted to read the next instruction, which has failed to execute for some reason.
4 Alignment Exception The printers main logic cannot access the memory for some reason.
5 Program Exception The printers main logic has issued an exception code.
6 Floating-point Unavailable Exception A floating-point instruction is executed when the MSR floating point enable bit is set to Disable.
7 Instruction Address Breakpoint Exception The printers main logic has attempted to look up an invalid address.
20 CU ROM Hash Check Error 1 CU ROM hash check error has been found. Check reproducibility if possible.
21 CU ROM Hash Check Error 2 The printers CPU has a checksum error in it's memory.
23 CU ROM Hash Check Error (resident) Seek service if restarting the printer does not correct the problem.
25 CU ROM Hash Check Error (DIMM2) Seek service if restarting the printer does not correct the problem.
30 CU Slot1 DIMM RAM Check Error An error has been detected in operation checks on the RAM in slot 1
31 CU Slot2 DIMM RAM Check Error An error has been detected in operation checks on the RAM in slot 2
35 Slot1 RAM Spec Error Check the specification and install in slot 1 RAMs supported by the product
40 CU EEPROM Error The EEPROM mounted on the CU board needs to be replaced
41 CU Flash Error The CU Flash needs to be replaced
43 Flash File System Version Mismatch Seek Service if restarting the printer and initialising the flash memory does not correct the problem
42 Flash File System Error Seek Service if restarting the printer and initialising the flash memory does not correct the problem
43 PS Flash File System Error An Flash Memory error has occured and the printer needs to be serviced if restarting the printer does not correct the problem
51 CU Fan Error The CU cooling fan needs to be replaced if restarting the printer does not correct the problem
70 Postscript Failure An error has been detected in your printer's Postscript Core.
72 Engine Communication Error A communications error has occurred between CU and PU boards.
73 H/W Overrun Detect An error has been detected in your printer's hardware input area.
74 F/W Overrun Detect Occurs when the firmware is unable to set video data in response to video DMA's data request.
75 VIC Limiter An error has been detected in your printer's
80 Parameter I/O Error An error has been detected in your printer's Input/Output area.
81 Parameter Consistency Check Error The EEPROM and flash memory reformatted and initialized.
102 Engine RAM Error An error has been detected in your printer's engine RAM.
103 Engine SRAM Error An error has been detected in your printer's engine SRAM.
104 Engine EEPROM Error An error has been detected in your printer's engine reading/writing the EEPROM at power-up.
105 Engine EEPROM Missing Error An error has been detected in your printer's Engine
106 Engine Control Error An error has been detected in your printer's Engine Controller.
122 Power Supply Fan Motor Error An error has been detected in your printer's Power Supply Fan Motor.
123 Humidity Sensor An error. has been detected in your printer's Humidity Sensor
124 Temperature Sensor An error has been detected in your printer's Temperature Sensor.
127 Fuser Unit Fan Error An error has been detected in your printer's Fuser Unit Fan Error.
131 LED Head Missing, Color: Yellow When yellow LED head connection cannot be detected
132 LED Head Missing, Color: Magenta When magenta LED head connection cannot be detected
133 LED Head Missing, Color: Cyan When cyan LED head connection cannot be detected.
134 LED Head Missing, Color: Black When black LED head connection cannot be detected.
140 Drum Up/Down, Color: Yellow An error has been detected in your printer's Yellow Drum
141 Drum Up/Down, Color: Magenta An error has been detected in your printer's Magenta Drum.
142 Drum Up/Down, Color: Cyan An error has been detected in your printer's Cyan Drum.
150 Drum Fuse cut NG, Color: Yellow An error has been detected in your printer's Drum Fuse.
152 Drum Fuse cut NG, Color: Cyan An error has been detected in your printer's Drum Fuse.
153 Drum Fuse cut NG, Color: Black An error has been detected in your printer's Drum Fuse.
155 Fuser Unit Fuse cut NG An error has been detected in your printer's Fuser Unit.
154 Belt Unit Fuse cut NG An error has been detected in your printer's Belt Unit.
160 Toner Sensor Error, Color: Yellow An error has been detected in your printer's Toner Sensor.
161 Toner Sensor Error, Color: Magenta An error has been detected in your printer's Toner Sensor.
162 Toner Sensor Error, Color: Cyan An error has been detected in your printer's Toner Sensor.
170 Upper Thermistor, State: Short An error has been detected in your printer's Upper Thermistor.
171 Upper Thermistor, State: Open Restart the printer. If the problem continues the printer will need to be serviced
172 Upper Heat Temp, State: High An error has been detected in your printer's Upper Heat Temp.
173 Upper Heat Temp, State: Low Turn the printer off to let it cool down, then restart the printer.
181 I/F Error, Loc. Duplex An error has been detected in your printer's Duplexer.
182 I/F Error, Loc. Tray2 An error has been detected in your printer's Tray2.
187 I/F Error, Loc. Control Pnale An error has been detected in your printer's Control Panel.
190 System Memory Overflow An error has been detected in your printer's System Memory Overflow.
191 Page Memory Overflow An error has been detected in your printer's Page Memory Overflow.
200 PU F/W download Check Sum Error Error during PU flash download
201 PU F/W Flash Write Error An error has been detected in your printer's PU F/W Flash Write Error.
202 PU F/W Flash Data Missing An error has been detected in your printer's PU F/W download Check Sum Error.
203 Engine Page Sequences IMAGACK Error An error has been detected in your printer's Engine Page Sequences IMAGACK Error.
204 EnginePageSequences IMGSET Error An error has been detected in your printer's Engine Page Sequences IMGSET Error.
2005 Oki Data Americas, Inc.
tip
EPrinter Not Detecting iPhone or iPad to "Airprint" or "Direct Print"
I run an ePrinter wirelessly (WiFi) off a ASUS EA-N66 wireless repeater. This tip pertains to a HP 6525 printer in case you find this attempting to correct the same problem.
When first connected everything connected except the "Airprint" features or 'Direct Print" off my iPhone and iPad. I found the default printer settings were set to "Simultaneous IPv4 & IPv6". The iPhone/iPads communicate at IPv4. Theoretically they should function in the "Simultaneous IPv4 & IPv6" setting but they did not. Changing to the "IPv4" only setting corrected the issue and the printer functions with everything I have including a WiFi PC laptop, a Wifi Mac, iPhone and iPad.
Need help connecting my printer to my computerWhat's your problem?
turn off your computer. plug in your printer to power. plug the printer cord into printer and then into computer. turn on your computer. if you have the cd that came with it place it into the cd drive once the computer boots up. your computer should detect the new equipment and walk you through the set up wizard. if not go to the control panel and "add hardware" to tell your computer to detect the new equipment which will start the install wizard... good luck!
9helpful
4answers
My cherry mobile phone cannot detect the sim card
do u have for cherry mobile flare?
Jan 28, 2012 • Cell Phones
I have a gigabyte ga-945gcmx-s2 and its giving me problems like freezing while detecting new hardware,showing blank screen after the beep and beeps going on.Can someone please help me with this problem
This sounds like a problem with your new Graphics card. (This is just an assumption.) When the Os loads a new graphics driver it can cause a slow down and screen flashing. It is better to download the correct (most up to date) driver for your new hardware before you attempt to install drivers from the Hardware Detection Wizard. These aren't always the most appropriate drivers. Enter this site into your browser for the correct Drivers for your Motherboard.
http://ee.gigabyte.com/products/page/mb/ga-945gcmx-s2_66/download/
Hope this helps. Good luck ,and if this doesn't help contact me again.
Hi i have a allin one hp1215 and need to scan with it but not done it before need help please
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. take the test print on the printer and this must be set on the scanner and clicked for ALIGNMENT. This is an automatic process and it will attempt to do it and calibrate. If there is any error , then you need to repeat the process once again.
Thank you for using Fixya
Izaakzakei cant get my printer connected to my laptop i have downloaded the driver but its still not working
You need to install the softeware first with the printer unplugged from the computer!
Insert your softeware disk and restart your computer, if computer doesn't detect new software when it is rebooting....than go into your control panel...click on install new software.
Once that is installed, you'll need to restart again with the printer hooked up this time.
Again, if computer doesn't detect new hardware, go into control panel, click on install new printer, you will have to select the make and model, or if you have the disk, select have disk, then next...you computer should install the hardware for you printer.
After installed, restart again...to see if if new software and hardware is detected and is being installed.
Go to your printers, from your control panel, and see if your printer is there, if not select, add new printer, it will take you through the process from there. Make sure you select this to be your default printer!
Happy printing!
Shows 'out of paper' when it is not
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge and the paper detect sensors, if faulty this must be replaced.
Won't print
Check and see if the USB cable is connected from the computer to the printer and it is powered. The computer will detect a new hardware. You can If the drivers of the printer are installed
  1. go to start then printers and faxes if you are using windows xp
  2. an icon of the printer will be seen with the name of the printer
  3. you can right and set it as default if not set
CAN'T INSTALL SOUND DRIVER FOR zYREX T14c COZ THERE'S NO SOUND HARDWARE DETECTED
Hi.
First option: Go to bios setting power on your PC then press F2 or DEL if you see bios setting highlight advance setting then search for audio device need enable and press F10 to save and exit.
boot to your operating system, try see device manager for sound hardware detection.if detected just install sound driver.
Second option: if you do first option not yet working sound card. I recommend you purchase USB sound card external.it's very easy to install.
hope can help you.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
