SOURCE: need to add a computer to the DHCP client list of Belkin router
You can't add a computer to DHCP Client table manually, because DHCP client table is automatic. If you wanna know the MAC address of your computer, go to Start > Run > type CMD and press enter. On the command prompt type in IPCONFIG/ALL and look for Physical Address. That is also the MAC Address of your computer.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click Setup > Basic Setup.
Step 3:
Make sure that the DHCP Server option is Enabled. Click the DHCP Reservation button if you want to assign a fixed local IP address to a MAC address.
Step 4:
When you click on DHCP Reservation, a new web browser window will pop-up. Click the Select checkbox to reserve a client's IP address. Click the Add Clients button afterwards.
Step 5:
If you want to manually assign an IP address, enter the client's host name in the Enter Client Name field. You can do this as well in the IP Address and MAC address fields.
Step 6:
Click the Add button.
Step 7:
A list of DHCP clients and their fixed local IP
addresses will be displayed at the bottom of the screen. If you want to
remove a client from this list, click the Remove button.
On this window, you can do any of the following:
• Click the button to save your changes.
• Click the button to cancel your changes.
• To view the most up-to-date information, click the button.
• To exit this screen, click the button
If you need more help come back.Post / thumbs / testimonial are welcome!.
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
• To exit this screen, click the button.
