Canon PowerShot SD1300 IS  IXUS 105 Digital Camera Logo
Posted on Aug 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My son dropped our Canon Powershot SD 1400 IS. The lens was stuck out. Managed to figure out how to fix that and get the lens back in, but it now does not focus properly. It will only focus properly if I don't zoom out at all. If I zoom out even the tiniest bit then it won't focus properly. Any suggestions would be appreciated. Thanks
Juan Calca?o
Level 2:
New Friend:
  • Expert 164 Answers
  • Posted on Aug 23, 2011
Juan Calca?o
Expert
Level 2:
New Friend:
Answers
164
Questions
0
Helped
26855
Points
482
It looks like the autofocus system got damaged, take it to a service center for repairs.
I just got a canon powershot sd 1400 is for christmas and i charged the batttery and then put it in my camera and automatically came up was lens error automatically shutting down
Make sure that the battery is charged fully. It may not have enough power to operate the lens on startup. If the battery is charged fully, and it keeps doing this, take back the camera tomorrow to the store that you bought it from.
For others reading this, that did NOT just receive a brand new camera that you can take back to the store. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try. (jillmur3, don't try these. take yours back to the store)
2answers
Lens Error
lens circuit got crack replace it
3answers
Have a powershot sd550
E18 is a lens error. My guess would be sand got into your lens (into the gears, etc.). These guys should be able to take care of you. http://www.darntoothysam.com/servlet/the-1730/Canon-Powershot-SD550-Camera/Detail
Canon Powershot A510...
The a70 drops a screw in to the mechanism.
you will need to take the unit apart carefully as it is intricate.
I used a web site to show me but have lost the link.
try looking for cannon A70 problems / erors Etc.
Focusing wont work after dropping
probably the lens inside is damaged or the mechanism which moves the lens is damaged. Focus works with a moving mechanism which moves the lens back and forth.
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
