I have a Sony handycam, recently new and not used much, maybe 3 tapes through it. I recently tried to play back some footage on the tv and did not get any sound, so thinking it was the cables I unhooked them and tried to turn up the sound on the playback on the camera....it shows the sound all the way up but there is no sound comming out of the camera!!! I tried taking out the battery, exchanging tapes and even pushing the reset button on the camera body inside of the LCD screen. Nothing is working and I need help!
SOURCE: computer mode
hi follow this steps: Make sure that you have installed the USB driver for the handycam. You can download the drivers from this link: Sony Asia Pacific Support Website--Download Page for HC40E USB Driver for Windows. Connect the handycam to the AC adaptor (the same as putting it on charge). Set the handycam to USB stream mode. (Press P-menu, press MENU, Press EDIT/PLAY, Press USB MODE, Press USB Stream.) Set the tape at the point from where you want to start capturing in PC. Connect the handycam and the PC with the USB cable. (USB-Mode appears on the handycam LCD / viewfinder.) Start Windows Movie Maker. Click on the 'Capture..' link to start the wizard. Select the Sony Digital Imaging Device. Click Next. Specify the file name and path for the capture video. Click Next. Select the desired capture format and Click Next. (Leave it to recommended setting if you are not sure.) The dialog box now displays the Start Capture and End Capture buttons on the left and preview window on the right. Play the tape on the handycam. The video from handycam should appear in the preview window of WMM. Click the Start Capture button to start capturing the video. Click End Capture to pause or stop recording. Click the Finish button. The .wmv file will be saved in the path specified in step 7.
SOURCE: black lcd screeen on my sony handycam
first check the iris of the camera if it is opening,you will see this when you look inside the lens of the camera when you turn on and off the switch at camera mode if the iris is opening....if the iris is ok the second problem may occurs of your camera is the ccd image sensor....go to a sony service center for replacing that...i know it is free for replacing that sensor cause that is the recall product not only on sony but in other brand because the manufacturer of their sensor is only one company....
SOURCE: Sony Handycam DCR-IP7E Micro MV Digital Camcord
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
SOURCE: Capturing Footage with Camera
USB streaming does not work for Windows Vista. Use the firewire/ilink connection instead.
Roger
SOURCE: Sony Handycam disc error when i try and finalize it
what type of disc--r -rw +rw? try to finilize in someone elses camcorder if possible and see if it reads it-does it play in camcorder still?
Same problem with HC27E. If i make a loud noise next to the mic I can hear a crackle / distortion, but no sound and other time.
