I need to reset my toshiba satelite A215-S4817 to factory default
This is a laptop not a desktop !!
Restoring factory default settings on your computer
can be done within a couple of hours, without any need for the recovery discs.
First, you need to back up any data and information
that you want to keep, such as documents, pictures, and downloaded email, since
everything will be erased from your hard drive after restoring the factory
settings on your computer.
If you haven't restored factory settings on your
machine before, do not worry.
With proper instruction, you can have your computer
back to its original state within a few hours at most.
Restart your computer and proceed to Step 2 before Windows begins to load after
reboot.
If you are restoring a Toshiba model, hold down the
"0" (zero) key as you turn off the machine, then skip to step three.
Access your computer's "PC Recovery"
feature by entering the correct button(s) for your machine.
This button varies, depending on the make of your
machine.
HP and Dell users will hit the "F11" key,
whereas Acer and Sony users will enter "F10."
If you own a Samsung model, use "F4."
Select "Destructive Recovery," or
"Restore Original Factory Image," from the list of options that
appear on the next screen, then click "Continue."
A destructive recovery will erase everything on your
machine and reinstall the operating system.
Wait as the factory settings are restored on your
computer.
Windows will require you to make date, time, and
language settings on the next set of screens to follow after your machine
restarts.
This process can take anywhere from a half-hour up to
2 hours to complete.
