Question about AEG HK955070CB 41 in. Electric Cooktop
UNLOCK THE LOCK OF CHILDREN IN CERAMIC - AEG HK955070CB 41 in. Electric Cooktop
  • AEG Master
  • 3,740 Answers
Hi and welcome to FixYa,
I can not insert the symbols here to properly answer your question so, I found the manual and you can read the steps on page 9 here:
http://awadnahas.net/pdf/UserManual/bf7e9e9b-cc9e-46fc-94a7-5965a2d61b18.pdf
This is copy and paste from the manual and the symbols will not come out:
Switching off the child safety device
• Start the hob with ( ' ). Do not set the heat settings . Touch for (Up arrow) 4 seconds. The
symbol ( 0 ) comes on.
• Stop the hob with ( I )
The symbols I typed above are not 100% as they appear in the manual.
Thanks for choosing FixYa,
Kelly
Posted on Aug 23, 2011
We cannot turn off the lock on our ceramic cooktop and it keeps on beeping.
Try cutting power to it to reset electronics. If that doesn't work, then most likely a control issue
Nov 05, 2017 | Cooktops
Hi, my mother has a Schott Ceran induction hob. It's very good but occasionally randomly locks itself and we cannot find a manual to tell us how to unlock it or locate the model number.
The reference to Schott is the maker of the ceramic glass. The label identifying which brand and model number will be located on the base of the cooktop.
If the cooktop itself randomly locks itself, it would most likely be related to the touch panel and the sensor plate that would require replacement.
The lock would be the child lock, and usually holding down the key symbols for a period of 5 secs should remove the lock.
Nov 07, 2016 | Cooktops
Child lock turn off
For the Candy CH642B cooktop:
LOCKING BUTTON OPERATION
The locking function prevents the children from starting the hob. It is also used for cleaning the control strip as the controls can be locked without the hob being on.
To lock the hob :
- Press the on/off button
- Press simultaneously " - " button and " + " button of the front right zone (CH 633 front left zone), and then press again on the " + " button of this zone.
When the hob is locked, the locking indicator " L " is displayed on all zones for 20 seconds.
To unlock the hob :
- Press the on/off button. The locking indicator " L " is displayed on all zones.
- Press simultaneously the " - " button and the " + " button of the front right zone (CH 633 front left zone), and then press again on the " - " button of this zone. The hob is unlocked.
Dec 05, 2015 | Cooktops
I can't unlock the stove on my kenmore ceramic cooktop
I was cleaning my range hood and leaning over I somehow set the lock on the cook top. How do I unlock it?
Sep 08, 2013 | Kenmore Elite 44173 30 in. Electric...
I can't unset the child safety lock on my diplomat ceramic hob
get the model number if a cooktop will be underneatth on sticker.... go to kitchaid.com and locate thier manuals and literature section where u can download a copy or print one out.... hope this helps
Feb 05, 2010 | Cooktops
All-Lock
If you enter the "Clean mode" then wait for between 2- 2 1/2 hours the lock mechanism should release. I'm not precisely sure of the time allotment. Use caution, the oven gets very hot and could cause you bodily harm. Thank you, Dana
Sep 30, 2009 | Cooktops
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Child lock on for neff t1443
gud day,not all models of ceramic hob have a child lock,check it 1st ur unit if have it,if we have,touch the circle w/sign of key to lock the ceramic for ur child,to unlock touch again.u see the ligth red is on it means the lock is in ON.easy to unlock even ur child by touching the key sign,for ur safety to not use ur unit,unplug the unit if it not use.
Aug 21, 2008 | Neff 23 in. T1443 Electric Cooktop
Cooktop shut off and lock itself up
36" electric wolf brand cooktop. Goes off completely after just few seconds sometimes 30 sec. sometimes minute..Repair man looked at it-thinks either something electrical or some sensor messed up.He took apart look at electric ribbon nothing looked over puts back together..turns on and it goes completely blank again..no error codes..any suggestions
Feb 22, 2008 | Cooktops
AEG HK955070CB 41 in. Electric Cooktop Logo
707 people viewed this question
Top AEG Cooktops Experts
Marvin
Marvin
Paul Carew
Are you an AEG Cooktop Expert? Answer questions, earn points and help others
