Your printer need to reset its ink counter... to solve your problem follow the instruction step by step..
Step 1: Entering Service Mode
* While the printer is OFF, press and hold the Start/Stop button (Resume/Cancel in some other models).
* While holding the Start/Stop button, press and hold the POWER button.
* When the POWER LED (green light) lit, release the Start/Stop button (still holding the POWER button).
* Press the Start/Stop button TWICE (still holding the POWER button)
* Release the POWER button.
* Wait for the LCD to display "0? (zero).
Step 2: Using Resetter / Software
Download Ressetter ; http://www.ziddu.com/download/10241255/ServiceTool_1050.zip.html
* Run "service_tool 1050.exe".
* Confirm detected USB-port numbers on USB port column.
* Click "Main button" on Clear ink counter section. Make sure there are papers in the paper feed because the printer will print after the process is complete.
* Click "platen button" on the "Clear ink counter" section. The printer will print again.
* Turn off the printer and then turn the printer on. You printer is ready for use.
about 7 months ago
Waste ink absorber full or platen waste ink
absorber fu
First Step : Set The Canon PIXMA MP287 To Service Mode. To do that, follow this step, it's so easy.
Second STEP : Reset Canon PIMA MP287 Using Resetter. Open the mp287.exe, and then follow this step.
