Hi! computer has a beep codes that coresponds to a hardware error beep codes link probably your memory or video card has a failure try to reset all the connectors and clean all slots, memory and video card. this may help.thanks
Blue screen could be the windows files getting corrupted due to a virus, file fragmentation or a failing hard drive, overheating cpu or failing memory.
The beeping usually indicates a hardware failure, first open the computer and see it the CPU heatsink is in place properly seated and fan is connected and spinning.
Second with the PC off, remove and reinsert the memory.
These are just a few things to check , most likely the hard drive has failed and needs replacing.
pressing certain keys during bootup can sometimes isolate the issue, but only if the monitor still shows a picture
I hope this helps
Thanks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
