The name for your keepsake is accutron. The tuning fork represents the two coils. Having said that unfortunately if it no longer works their is little you can do. They have been out of production for some time now. But you can replace the entire movement, eBay will be the best place to start for a reasonable price. Your local jeweler will soak you. The most common battery replacement is a renata 394 although i cant be sure unless I see the movement.
SOURCE: Caravelle by Bulova watch strap adjust
You need to push the pins out in the direction of the arrows. Then take out one link from each side. Put the pins back in the same way they came out, with the slot pointing the same direction as before.
SOURCE: how do I remove extra
there shoulf be screws on the side of the watch to remove. If not they will queeze together and pop out and you will need a tool to do this with. So basically if that the case you need to take it to a dealer or shop and have them remove it. Thats the case with some high end watches.
SOURCE: Need extra bracelet lings for a Tag Heuer Indy 500
Hi. I just received the Tag Heuer Indy 500 with steel bracelet today for christmas from my wife. I'm a smaller man and had to take out 3 links. I'd never sell this watch so if you would like them...just write.
[email protected]
Charles Roscow
Silver Spring, MD
SOURCE: How do I remove links from stainless steel
The band has pins in it which can be removed by tapping them
SOURCE: Cannot open bracelet on Bulova 11606355 watch
Try taking your watch to a local watch shop.
If there is something wrong with it, you can only tell by handling it. Alternatively if there is a special way to do it they will probably know it.
