E3 means that the stove is getting overvoltage.
Plug it through a voltage stabilizer
It is possible that there is fault in the circuit as the drive section seems to fault when the current requirement is high. It is also possible that there is a component possible a semiconductor- MOSFET- that has gone weak during the power outage and so fails .
It is best to have it checked now as it might save a larger expense if the whole unit fails. Also someitmes it can be a silly dry soldering which can be done up immediately. So get support if youa are not able to DIY.
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
