How do I reset my router back to the factory default settings?
The router's admin page is http://192.168.1.1 or http://192.168.0.1 and the default password should be either "admin" or "password" without quotes. There should be a choice under "Setup" called "Factory Reset". That will erase the settings and reset it like new.
Alternatively, you can follow the procedure as given below on all the brands I've tried (Belkin, D-Link, Linksys)
1. hold the reset button for 30 seconds (don't release)
2. unplug the power (still holding reset) for 10 seconds
3. plug power back in (still holding reset)
4. hold reset for another 30 seconds - the lights will usually begin flashing in some odd pattern
5. release the reset button
6. wait 1 full minute or until the lights stop flashing
7. unplug the power for 10 seconds, just to do a reboot
8. verify the settings (e.g. SSID) are back to the defaults
Get instant online router/wireless router support at http://www.vtechsquad.com/wireless-router-support/ to fix D-Link router/wireless router issues.
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset. Step 2 Hold paper clip down for 10 seconds and release. Note: Do not repower unit during this procedure. Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset. Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
how was the name reset and by who??????
if you mean you have to reset your router to the factory default settings
(note all settings will be lost you will need to reconfigure the router)
you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, depending on your router) to reconfigure your router settings or if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
hope this helps
