SOURCE: Musty stale smell
HI thanks for your question. ALL front load washers have the same problem.MY solution every wash use 1 cup of vinegar in time will solve the problem. thanks the appliance doc. please rate my answer. thanks.
SOURCE: LG TROMM WM1814CW won't stop filling. Says
Over
flow error
Water
is overflowing , (water level frequency is over 213). When
FE is displayed, the drain will pump out automatically.
Replace the Overfill pressure switch(AKA-Switch assembly sensor swi)
SOURCE: My LG Tromm WM1814CW is not draining. I cleaned
Check inside the filter housing with a flashlite for debris that got around the filter. If it is clean, you have a bad pump and it needs to be replaced.
SOURCE: LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Is this a new
installation?
In new installations, this error can sometimes present
because of a miscommunication between the control panel and the wash
motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing
machine.
Step 2: While the washer
remains unplugged, press and hold the [Start/Pause] button on the front
panel for 5 seconds.
Step 3: Plug the unit back in,
and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using
non-HE (high efficiency) detergents or too much detergent will cause
stress on the motor. In addition, detergent residue can also cause
leaking and odor. Follow these steps to resolved an LE error code caused
by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for
30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn
on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin
Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove
the clothing items from the machine. Turn the power back on and select
[Rinse and Spin] and then press [Start/Pause]. This will remove excess
soap suds and light residue from the drum. Repeat this step until no
visible suds are in the drum of the washer.
Has a large load size been used
with a gentle wash setting?
Gentle wash cycles such as Perm
Press, Delicates, Hand Wash, and Wool/Silk should only be used for
smaller loads. Because the cycles are more gentle while tumbling and
spinning, too many items in the drum can register as an issue with the
motor. In this instance reset the unit and run a test rinse and spin
cycle.
Has the washer been
overloaded?
Single bulky items or large
loads can add extra weight to the drum and place stress on the motor.
Remove some of the clothing and restart. If the issue is still present
after a few items have been removed, unplug the washer for 30 minutes to
allow the motor to cool and then restart the cycle.
SOURCE: have an lg tromm washing machine wm1814cw, it
'ce' stands for Current Error i.e. the motor (or something else) taking too much current to run requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
