Hello! Welcome to FixYa
If you are facing error E32 it means lens becomes stuck in the barrel. There are some solutions you can try to fix but the
probability is that you will have to get it fixed by a professional.
First connecting your AC adapter or USB cable.Try holding the
shutter button while switching on the camera. Look at the lens and if some of the lens circles is misaligned or not concentric then
try wiggling it. Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
If your camera is still under warranty then best solution is to take it from where you purchased before trying any of these steps.
I hope this solution helps you.
Thank you for using FixYa
