To get the Network Unlock code at low cost you can reach here
Superunlockcodes.com and get the code and get the Free Unlock instructions at here Mobileunlockguide.com and Unlock it...
Unlocking via codes is the best method for unlocking the mobile ,Dont prefer software or cable , In order to unlock your mobile in the safest way make use of the unlock code here mobile-unlocker using unlock code specified here , unlock your mobile safely , I unlocked my mobile recently making use of this site & gain solution.
SOURCE: samsung galaxy android unlock..cannot unlock my
Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , [email protected]. Now this google id on the top right corner of the page would be displayed as [email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like [email protected]) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
SOURCE: Samsung Galaxy S GT- I9000 Sim Network Unlock
By using the codes, you can remove your sim lock..This unlocking code will be provided by your network provider or you may get it from Classicunlocking.com ..They will help you to unlock your mobile..
