Computers & Internet Logo
Posted on Aug 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No increase in range - Computers & Internet
Anonymous
Level 2:
New Friend:
  • Expert 83 Answers
  • Posted on Aug 20, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
83
Questions
0
Helped
18210
Points
278
Hey kenat. To increase the range of your wireless signal to increase signal strength, try pointing the antennae as approximate as possible to your receiver. If you have already tried that, then use the old Aluminum foil trick. Get a small square of aluminum foil and wrap it around your antennae. Make sure the whole antennae is wrapped with the foil and it's usually best to keep some more hanging off. Because Aluminum is conductive, this will increase the strength of your wireless signal, and at the same time your range.
If all else fails you could always purchase a multi-antennae router which usually has 3 or more antennae.
Have fun :)
4helpful
4answers
How to Increase the Range of Wifi?
Check the rules in your country. Most countries limit the transmission range to 50 feet to reduce interference.
1helpful
WHAT IS RANGE?
The range of a walkie talkie is line of sight. There are many ways to increase range, but not for GMRS radios. You did not specify what type of radio. There are business radios that can work over the internet also, allowing an increase of range unheard of just ten years ago. Please, more information so I can give a better answer,
2answers
In my nokia 5200 , only external memmory of 2gb . How can i increase my phon's external memmory up to minimum range up to 4gb .
hi try going into the phones settings and select memory then go to external memory and choose increase to maximum if that doesnt work then try inserting a blank 4gb memory card and then formatting it in the phone may work that way.
1helpful
I just install hot point gas range in my kitchen and the range oven and burners flame fail to increase as I turn up the the knob. Also the oven does not get very hot, the temp may be about 300 to 350...
Sorry to read about your problem, I hope this helps you out.
you may have a defective gas flow regulator
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
How to increase the transmitter range of my key less entry
max range is achieved with a new battery,the output/power dictates how far you can transmit a radio wave.....without opening every car in the parking lot...so if you increase its output(you need to be an electronics wizz)
1helpful
How to increase wifi range of my laptop c700
As far as i know the range of the integrated wireless adapter cannot be increased of your laptop. Still you can, if you purchase an external wifi adapter. A long range of wifi adapters are available in the market. Select one as per your requirement.
Please come back and rate my solution if it turns helpful for you and also if you need more clarification. Thnx :)
Increase range for remote starter on 2007 grand prix
Try changing the battery in the key fog. If that doesn't work you can try finding an aftermarket key fog with a greater range. It is probably just default range.
2helpful
Increase range of Wireless Keyboard and Mouse
They are really not designed for longer range but here are some ideas from people that have found ways to increase the range. Of course, any internal modifications void your warranty and can cause damage to your device and/or computer! So maybe you can just try the external wire tricks.
Grand Canyon Tech
Grand Canyon Tech
