Maytag MER6772 Gemini Electric Kitchen Range Logo
Posted on Aug 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The F1-2 error code appears on the range and the oven stops working but stove top burners still function?
Anonymous
Level 3:
Genius:
  • Master 1,157 Answers
  • Posted on Sep 23, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1157
Questions
Helped
418565
Points
2951
Hi adsdunn2,
The F1:-2 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
(Positive feedback will be greatly appreciated.)
2answers
My Samsung gas range stove top won't stop periodically beeping and there's no error codes
If your Samsung gas range stove top is periodically beeping and there are no error codes, it is likely that the burner is not properly connected. Make sure that the burner is securely connected to the stove top and that the power switch is in the "on" position. If the problem persists, you may need to replace the burner or contact the manufacturer for assistance.
I am looking for a thermostat for my Samet gas stove. Having difficulty to find the part. Any replacements that might also work?
send me a picture of the thermostat body and i may be able to help.
35 years + restaurant equipment repairs.
Theseafox Enterprises
Why does the f1 code appear when cleaning my oven
Its an error must be the blower motor..one blower will blow air to cool tge chamber. try to open the unit & look inside
Frididaire electric stove the oven has stopped working
Good Afternoon Friend, thank you for allowing me to assist you!
I understand you are experiencing an issue with the oven of your Frigidaire range. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? Do the burners/elements work? With this information I can assist you better in pinpointing the problem.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you! -Z
I have kitchen aid in the counter range, the bottom heat element is bad. The element has burnt and has a 3" piece that has separated. At the same time the oven stopped working the burners stopped working...
The oven element will not affect the top burners, Unless it tripped the breaker at the panel when the element burned it two. Is there power to the stove? The top burners have their own power and control separate.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
4helpful
3answers
KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
15helpful
3answers
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Top Maytag Kitchen Ranges Experts
vince
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
