The new battery is twice the size and it doesn't allow the screen to open fullyThe new battery is twice the size and it doesn't allow the screen to open fully
You can't post conmments that contain an email address.
That is not normal definitely your battery has some problem and needs a replacement because a normal working battery should last for about 2 hours or more..
Normally, a new battery pack comes in a very low charge condition and must be fully charged before use. Refer to the user manual of your portable electronic equipment for charging instructions.
A new Dell Vostro A860 Battery needs to be fully charged and fully discharged or “cycled” as much as five times to condition them into performing at full capacity.
Your equipment may report a fully charge condition in as short as 10 to 15 minutes when the new Dell Vostro 1015 Battery is being charged for the first time. This is a normal phenomenon especially for Nickel Cadmium (Ni-Cad) and Nickel Metal Hydride (Ni-MH) chemistries. When this happens, remove the dell vostro 1015 battery pack and let it cool down for about fifteen minutes then repeat the charging procedure.
“Conditioning” (fully discharging and then fully charging) is necessary so as to maintain the optimum performance of a sony vgp-bps8 battery, and is recommended at least once a month particularly for Ni-Cad and Ni-MH batteries. Failure to do so could result in reduced charge capacity and can significantly shorten the sony vaio vgn-fz battery pack’s useful life. Lithium Ion batteries do not require conditioning.
It is normal for a acer aspire 1410 battery pack to get warm when charging and during use. However, if the acer aspire 1410 battery pack gets excessive hot, there may be a problem with the portable electronic equipment’s charging circuit and should therefore be checked by a qualified technician.
Rechargeable batteries undergo self-discharging when left unused for long periods of time. This is normal particularly in the case of Ni-MH and Li-Ion chemistries. For best results, always store a battery pack fully charged. It should be removed from the equipment and kept in a cool, dry and clean place.
The amount of runtime a hp 510 battery produces depends on the power requirements of components in your electronic equipment. This could be the hard drive setting, screen intensity and back-lighting on notebook computers, the liquid crystal display (LCD) screen and floodlight feature in a video camcorder, or the tri-mode communications network of a cellular phone. Always refer to your equipment’s user manual for power management settings.
what you may have to do is write the OS on an other computer by linking
the hard drive of the laptop to a computer with a CD ROM drive. after
you write the OS on the hard drive you place it back on the laptop with
no drives.
You really cannot adjust screen brightness through windows unless you have calibration software that uses a light detecting frame... I had a Sony Vaio PCG-something and Vista really screwed it up as well. Here's the Sony eSupport website where you can enter your model and reinstall some originals drivers for the computer that may restore functionality to your function keys: http://esupport.sony.com/perl/swu-download.pl?upd_id=2207&SMB=YES
Some things you can do to save battery power: turn of your wireless if you're not using it (there's usually a wifi switch on most laptops, turn it off), set your screen saver to come on as quickly as possible, run as few programs as possible and try to avoid graphic-intense programs.
