Maytag MZD2766GES Side by Side Refrigerator Logo
Posted on Aug 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does not cool either side fan runs and compressor seems to run
Marat Brikov
Level 3:
Director Badge:
Uploaded 100 video answers.
  • Maytag Master 518 Answers
  • Posted on Nov 21, 2015
Marat Brikov
Maytag Master
Level 3:
Director Badge:
Answers
518
Questions
0
Helped
324347
Points
3123
2 possible issues. If compressor running, but not cooling - No freon in the system, or compressor valves are bad, not compressing freon. Ideal would be to check pressures on the system while its running. Could be some kind of restriction. most common problem i would guess low freon level. Here are 2 of my videos i have on my channel. first is leak found at evaporator coils. i used leak dye to find it, second video is replacing compressor, but had compressor completely down. installed 3-n-1 hard start kit, but compressor did not come on, so replaced compressor with filter drier. Hope this will give you an idea what to do next.
raj somaiya
Level 3:
  • Master 5,370 Answers
  • Posted on Aug 19, 2011
raj somaiya
Master
Level 3:
Answers
5370
Questions
0
Helped
3569275
Points
14579
I agree " fan runs and compressor seems to run" ------- But compressor should run while cooling cycle is going on, and compressor should stop running when defrosting cycle starts.------- In your case compressor is running non- stop.This is because the compressor is got weak,and the weak compressor is not able to cool the refrigerator fridge and freezer section.------- The problem is compressor, its got weak---------- Click this link below and follow the troubleshooting,:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ------------ This will help.Thanks.Helpmech.
5 Related Answers
docjohn174
john gagnon
  • 943 Answers
  • Posted on Sep 27, 2008
SOURCE: not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
A
Anonymous
  • Posted on Sep 01, 2007
SOURCE: Freezer and Fridge side not cooling
check the condenser is not blocked with fluff, it is situated iether behind the lower front trim panel or in the back near the compressor depending on the exact model also ckeck the fan near the compressor in running freeley.
A
Anonymous
  • Posted on Nov 03, 2008
SOURCE: Side by side (KSRB25FHSS05) loosing cool in freezer
jame open the back cover of the evaporator are in the frezeer section you will a type of radioator thats is your evaporator now check for frost if just frosted is ok if all iced up and a lot of ice then yoy have a defrost problem if no frost and compressor is running and you are sure of that then check the name plate for the date the unit was manufacture is less tha 5 years call a tech ou to check for freon or restriction ;leaks if less than 5 years is free but you have to be sure is running becuase the seal system in the only one under warranty ok
Anonymous
  • 158 Answers
  • Posted on May 06, 2009
SOURCE: fregerator not cooling
it can be fan defect or fan switch or timer as well as thermostat defect causing build-up of ice jamming the fan
Anonymous
  • 1136 Answers
  • Posted on Jun 27, 2009
SOURCE: Does not cool. Compressor is running, fans are
Hi, Look in the freezer section and see if there is frost building up on the rear inside panel. If the is frost, on of three parts are bad in the automatic defrost.
If there is no frost, the compressor might be weak and not pumping the coolant as strong as it should.
Remove the rear inside panel in the freezer sevtion and see if the evaporator is frosting at all.
Please let me know what you find so I can assist you further with this issue.
Vic
My GSS20IE side by side is not cooling the refrigerator side. The freezer seems to be fine. I unplugged the frige and can hear the compressor click off. When I plug it back in the compressor clicks on but...
Condenser fan near the compressor- Check to see if your have voltage at the fan. If you do the fan need replacing. There should be voltage any time the compressor is running.
About 36 hours ago our Whirlpool 25.2 cu. ft. Side-by-Side Refrigerator ED25CQXFW02 was not cooling (frozen was thawing, and refrigerator was not cold) the compressor and fan were running, I cleaned the...
depending on your model. if its just a reg, side by side, you more than likely need a relay/ overload which is located on the compressor,the relay only works after it cools down. unplug ref from wall, remove rear cover to see and touch compressor to see if it starts when you plug back in to the wall. if it doesnt start in three attempts. replace it. easy way to diagnose..
4helpful
3answers
Wont stay cool
does it cool and then stop when it does this is there frost in the fzr compartment or ice build up. Does the fans run at all do you hear the compressor and compressor fan running. Just need more info
Freezer dying first, fridge failing...
Is the compressor running. also check to see if the fan next to compressor is running. They should both run at same time..is the compressor fan running and compressor not? Could be the compressor start relay. Next, is there frost buildup on inside back wall of freezer? If so u may have a defrost control out or defrost heater or defrost terminating thermostat out. Greg
1helpful
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
My subzero fridge no longer seems to be cooling, its only 4 years old. Ive checked all the obvious stuff, do u have any suggestions?
Is unit running? Need to know if condenser fan (by compressor), ref fan, and compressor (the one on the right if this is a ref/frzr unit) are running.
Not cooling
Kenmore side by side not cooling: The compressor seems to be running (it's hot), the compressor cooling fan is running, the freezer circulation fan is running, but not the least bit cool anywhere.
If everything is working, that you can see and hear, then I think you are low on coolant. A set of gauges will show you for sure or if you take the back panel off in the freezer and look at the cooling coils, they should have a light coat of frost all over. If it is low on coolant then they might have some frost on a few coils or none at all.
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
