My 2000 XL 1200 Yamaha Waverunner will just click when i hit the start button i have a new battey and if i hold the mode button down the word code comes up and if i hit one of the bottons on the left a letters comes up and before i for get to say i changed out the starter to begin with i bought it not running. that would be great if you could help me thank you
Behind front storage container is a wiring harness, locate the single blue connector and disconnect, red light should be on dash now hold mode button down until it says SET. enter new code then reattach connector
your starter is shot more than likey try to jump the relay in that black boxs buy jumping the two post on that round relay if it does the same its the starter if it turns over its the relay or the start **** becareful jumping the relay no fuel around air bike out and you have to take off the exhaust manifold to get to the starter
my 1998 xl 1200 has this thing it the batter is changed or if it sits for awhile you have to hit mode then something that says code should pop up on the screen then hit a b c a and then it should be able to start. but your code may be different
first put a new battery in it. then put your lanyard in the handle bar clip push the start button make sure that you have a life jacket on when your in the water and make sure that u attach the lanyard to your wrist or life jacket
You do not have to reset the computer, but you do have to enter in your security code for the padloc security system. If you have forgotten your code or never entered one before, you will need to do that now. It is an easy fix. First, open the front hatch and find the blue connector. It will have only one wire in it. Disconnect that connector. Now, on your meter panel, hit and hold the mode button till the word CODE appears on the right gauge. At that time, hit any combination of any 4 letters from the buttons down the right. They can be all the same or all different, you just have to enter 4 letters. Now plug the blue connector back in, put the trunk back, and hit the start button. If it does not crank, hit and hold the mode button again and re-enter the code you just stored. After you enter the correct code, it will now say START and you are good to go.
