Plantronics - Bluetooth Headset Plus Base & Headset Logo
Posted on Aug 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Plantronics bluetooth will not turn on. - Plantronics - Bluetooth Headset Plus Base & Headset
Anonymous
Level 2:
Scholar:
  • Expert 126 Answers
  • Posted on Aug 19, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
126
Questions
Helped
63161
Points
167
I'm wondering if the the battery has died in the headset. The battery is not replaceable but you can buy a replacement headset, follow link below.
http://www.headsetsdirect.com/84321-01-510-replacement-headset.html
1helpful
2answers
Unable to turn on my plantronics 210 explorer bluetooth .therefore no light is showing in it. charger is fully charged
How to pair plantronics explorern240 with lg phone
On my LG phone under tools, is the bluetooth application -- turn this on. Once that is done, turn on your bluetooth, they should find each other. I have also included the directions from the user guide.
Plantronics Explorer 240 User's Guide
Good luck from Headsets Direct!
I am unable to pair my Nokia N96 with Plantronics Explorer 240 / 395 bluetooth headset.
If you see your Bluetooth listed on your phone: delete it then turn your Bluetooth off. Turn off your phone and take the battery out of your phone for a few moments, reinstall the batter and turn your phone back on. Turn your Bluetooth back on and try repairing them again.
Here is a link to the Plantronics Explorer User's Guide.
When I make a call using the bluetooth, I can hear who I am talking to through the bluetooth, but they can't hear me?????
Make sure both devices are fully charged. Turn off your phone and disconnect the battery for about 30 seconds (this helps to reset the phone). Make sure there are no other bluetooth devices interfering with the connection. Turn off your headset and carefully follow the pairing instructions on the link below for the Plantronics Discovery 925.
Plantronics Discovery 925 User's Guide
9helpful
4answers
How to pair to the phone
Please follow this procedure:
  1. In the headset press and hold the call control botton until the indicator turns red and then turns off, press and hold the call control botton until the indicator light continues to flash red and blue, the headset is now in pairng mode.
  2. In your phone, go to bluetooth conectivity and select scan for devices, select de Plantronics bluetooth headset from the list, enter 0000 for the passkey and OK/accept to bond them.
How to connect plantronics 330 bluetooth headset with my iphone 4
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
39helpful
Trying to pair my HTC EVO to plantronics explorer 233 Bluetooth headset
Had the same problem and called Plantronics. They reminded me about putting the earpiece in "Discovery Mode" by holding down the button when turning it on until it flashes blue/red. Then have the EVO scan for bluetooth devices. It found mine right away.
1helpful
Toshiba laptop with IOgear bluetooth adapter installed will recognize phone but won't detect plantronics explorer headpiece. I would like to use it to chat on skype
If the Bluetooth adapter can detect the phone but not the Plantronics headpiece, then there's no problem with your computer or your Bluetooth adapter. The problem has something to do with the Plantronics.
Try to turn the headpiece off, then turn it back on. Set it to discovery mode, then try to detect it using your computer. If that did not help.
Try to detect the Plantronics, using your phone. That will help you in isolating the problem.
Aside from that, make sure that no possible wireless interference while you're searching for the headpiece. Cell phone, base of the cordless phone should be away from the computer while you're searching for the headpiece. Because Bluetooth and cellphones/cordless phones are running on the same 2.4GHz frequency RF signal. They might interfere with each other.
My bluetooth Plantronics 220 won't turn on
my plantronics will not connect to my htc diamond without being on the charger.when i take the bluetooth off the charger it will not connect
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
