Question about Weedeater 25cc Gas Blower ()
I have a 150 MPH Weedeater featherlite gas blower. Model FL 1500T Recently it has not been running at full throttle. It cut off the last I used it and will not start. I replaced plug, cleaned air filter but it still will not start. Choke seems to be working okay. Any suggestions. Thanks. rskinner002@nc.rr.com
    Top Expert:
  • Weedeater Master
  • 53,770 Answers
Fit new diaphragms in the carby
don't alter any settings
just undo the housing screws and replace the diaphragms
Posted on Dec 12, 2017
Ralph
  • 130 Answers
SOURCE: My weedeater 150 mph starts
One cause of such a symptom could be an obstructed exhaust. Make sure the outlet of the muffler is not obstructed (ex. dirt dobber nest), also check the exhaust port by removing the muffler.
Posted on Feb 16, 2011
Testimonial: "Muffler did need cleaning as it was clogged with oil but problem still persists."
How to adjust carb on F25 leaf blower
Initial setting to start is 1 full turn on both low and high adjustments
Oct 07, 2014 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Where do I find the model ### ?
The model number is the 952711334 This is an XT200 Featherlight manufactured in 2004
Jun 21, 2014 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Fuel tubing to pump up carb.
-Try to swap to the other one it there are two lines.
Good luck
mai
Dec 06, 2017 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Where does the 2 wires connect running from the coil?
there will normally be an eart cut out wire that will go to the kill switch and another wire that earts the coil core which usually sits under the head of one of the coil fixing screws
Sep 02, 2012 | Weedeater Featherlite Blower 18 Cc 150 Mph...
My weedeater 150 mph starts hard and barely runs at full throttle. I put in new gas, plug, and clean air filter. Please help. John
Feb 16, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Is getting air in gas line, will not start
If the hoses are connected right and they are in good condition, it could be bad gas,sparkplug or carburetor needs cleaned and/or a rebuild kit. Check the link below for parts:
http://www.ereplacementparts.com/poulan-fl1500-type-blower-parts-c-16962_31724_31725.html
Feb 02, 2011 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Weedeater featherlite seized shaft
If you are talking about your crank shaft being stuck, there is nothing you can do that will work for the long haul. Usually what happens to cause this problem is running straight ( no oil added to fuel) gas to these 2 cylce engines. When you get a "lean seizure', the engine slowly loses power then quits. If you leave it alone for a while, the pull rope will be harder but it will start. The second tome it does this..........well your done. time to buy a new one. Sorry.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 10, 2010 | Weedeater Featherlite Blower 18 Cc 150 Mph...
How do you know whether to use 50:1 or 40:1 gas/oil ratio mix in a 2 cycle engine ?
should be written in the manual and on the lid if not i always run 40 to 1 better safe than sorry to much oil ratio can foul a plug running to light on oil can blow the motor
Nov 07, 2010 | Weedeater Featherlite Blower 18 Cc 150 Mph...
Weedeater 25cc Gas Blower () Logo
165 people viewed this question
Top Weedeater Garden Experts
Charles Tidwell
Mike Ceslow
 Russ Hill
Russ Hill
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
