SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue
The Out of Paper
message appears on the computer and the product stops picking up or feeding paper.
Solution
Step one: Reset the product
Step two: Check the condition of the paper and reload it
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
NOTE:
Do not load too much paper in the product.
Step four: Clean the rollers
Step five: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
CauseAny of the following issues can cause the error message to appear:
SOURCE: HP Officejet 6500 No scan Options
I am trying to scan, but when I press the scan button it states "No scan options. Refer to device doc to troubleshoot". However, I can't find my device doc. I am assuming there is an easy fix?
SOURCE: HP Officejet 6500 will not print after sleep mode
Move the printer to a different location and keep it closer to the connected device (e.g. router) and away from large metal objects / other electromagnetic devices for stronger signal strength.
SOURCE: HP Officejet 6500 E709 (new printer) will not
Hi ladarlak
There is no full feature driver for Windows 7 yet. Meanwhile HP have printed a workaround at http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01796879&lc=en&dlc=en&cc=us&lang=en&product=90764
SOURCE: Cannot coonect SCANNER (HP Officejet 6500 wireless) to my Windows
I have seen alot of problem/posts concerning HP AIO's and software issues. Typically some of the functions won't work or not recognized by solution center. Try a complete uninstall of all associated printer software, run registry cleaner if you have it, restart, then try completely uninstalling your Antivirus/firewall software. I have seen that just disabling Antivirus/firewall still causes faulty installations. Now, reinstall your printer software/drivers and connect cables only when told to do so. Some reason the AV/FW software blocks some of the AIO's apps from completely installing.
Hope this works...Good Luck!
