I have three GN9330e all doing that. It's a pairing failure, and probably why Jabra discontinued the product. Jabra will tell you to work with your retailer/distributor if you're even within warranty. They wouldn't provide me any other help.
SOURCE: Tried unmuting the headset
voice dial work throught your phone.unmuting the headset is it at the phone not at the headset.
SOURCE: One short beep during shutdown sequence
a short beep normally indicates that your phones network signal is low or absent, so you are aware that you are in a low signal area without looking at your phone, or two short peeps normally means the headset needs charging.
SOURCE: headsets keeps beeping and battery is not low
sounds like the non replaceable battery is bad get another headset cheap at www.n1wireless.com
SOURCE: How do you turn the volume down on a GN9330
check themanual and if ur too independant and threw it away print out a copy online
