Does everything else work?? If so, its just the turntable motor, simple to replace. there are three or four screws under the bottom. UNPLUG the microwave first.
From the description it is the magnetron, it will be expensive for the part alone, and keep in mind shops have different rates making impossible to give exact quotes, but I would estimate parts and labour at least $250.00 or more, if you decide to go with the repair make sure the magnetron is not a aftermarket product it will last about 6 months.
There are three things that will cause this, the magnetron "common problem" or the high voltage capacitor or diode. The above mentioned work together to heat the food and depending on the nature of the repair, parts and labor can approach the price of a new unit.
The keypad controller has probably developed a short in the membrane of the keypad, it must be replaced in order to get it up and running, but I suggest a maytag repairman to address this.
the unit that creates the microwaves called the "magnetron" has gone bad, or the circuits powering the magnetron have gone bad. there really isnt a cheap way to fix it, and not a undangerous way to fix it yourself. if your really like the microwave and dont want to part with it, you can try finding a repair shop that will fix microwaves, but they will probably tell you it would be cheaper to buy a new one. sorry
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
You can download Maytag owner's manuals and installation instructions here. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
